Any way to add paddle shifters to a base modle G37 w/o harness inputs on the column?
Old Aug 28, 2008 | 03:52 PM
LightningG37's Avatar
LightningG37
I know there is a mounting point for the paddles but on my car there is no harness inputs on the steering column. Does anyone know how it interfaces with the Tx or ECU? Has anyone figured out how to add this?
Old Aug 28, 2008 | 04:04 PM
Blackjack's Avatar
Blackjack
Search is your friend... There is a whole DIY on this.
Old Aug 28, 2008 | 04:09 PM
Blackjack's Avatar
Blackjack
http://www.g35driver.com/forums/tech...long-post.html
Old Aug 28, 2008 | 11:24 PM
LightningG37
thanks, but I don't think you fully read my post. I have seen posts for when the harness connections exist on the steering column, but not wiring for when there is none. Thanks for you post though.
Old Sep 2, 2008 | 05:02 PM
alti35's Avatar
alti35
I have the same problem in my 2007 G35 Sedan. I have the base model, and when I removed everything it turned out that I did not have the wiring. i ask the same thing, and other base G35 members said they had the wiring. I don't know if our cars are a fluke or if they have a journey and they think they have the base model. I'm really interested in resolving this problem.
Old Sep 2, 2008 | 06:30 PM
G37RacerX's Avatar
G37RacerX
I understood your post when I read the title. I remember seeing the thread about adding paddle shifters and I also remember it was for cars that did in fact have the wiring harness, just not the paddles. Your post was a valid one with a valid question. Sorry about the other useless replies, it happens, (alot).
I don't believe anyone has added the wiring harness you are referring to.
Old Sep 9, 2008 | 11:40 AM
The_White_G35's Avatar
The_White_G35
harness?
Did anyone figure this out or do they know what it would take to get a harness into a G that didn't come with one?
Old Sep 9, 2008 | 12:22 PM
CHI-TOWN G37's Avatar
CHI-TOWN G37
Have you talked with your dealer service department about adding the harness?
Old Sep 9, 2008 | 12:28 PM
The_White_G35
i just ordered an 09 g37x coupe and if it doesn't come with a harness i'd be in the same boat as the rest of the guys....the car doesn't even have paddles as an option if i pay extra or anything so this is what i'm gonna try i guess....i wish there was a harness i could buy somewhere to make it the right way....
go to the electrical part of this link...technically it should work right?
http://www.infinitiscene.com/forum/s...ead.php?t=1369
Old Sep 9, 2008 | 05:44 PM
LightningG37
I believe the answer was that the harness was for the entire car. I strayed away because I didn't want to pull the whole dash off but perhaps I could use just some of it..interesting. I'm pretty sure its over a grand though.
Old Sep 9, 2008 | 05:54 PM
The_White_G35
well the option i'm looking at would be a lot less then a grand...probably only 10 $ and an hour worth of time if it works......
anyone have any input?
Old Sep 9, 2008 | 06:17 PM
LightningG37
wow,I just went to the link, that's awesome. It might take me a while to digest it all though. I was really hopping that it was something like a few wires going from the paddles to the tranny.
Old Mar 7, 2009 | 08:40 PM
rmw00's Avatar
rmw00
YES, YES, YES... Finally figured out how to add paddle shifters to my 2008 G37 Journey Coupe. I'll post some pictures when I get time. You have to get a couple of connector contacts from your dealer. Insert them in connector M66 behind the dash and make your own harness. It does require soldering etc. Mine works great!
Old Mar 12, 2009 | 06:01 PM
alti35's Avatar
alti35
What connectors do I need and where is this M66 conector located???
Old Apr 12, 2009 | 09:45 AM
rmw00's Avatar
rmw00
Here are the pictures: http://www.flickr.com/photos/rmw00/s...7614971013297/
You can also go here to download the Infiniti tech manuals:
http://www.infiniti-techinfo.com/help.aspx
