Any way to add paddle shifters to a base modle G37 w/o harness inputs on the column?
Old Apr 13, 2009 | 01:11 PM
t-bone1924's Avatar
t-bone1924
Originally Posted by rmw00
YES, YES, YES... Finally figured out how to add paddle shifters to my 2008 G37 Journey Coupe. I'll post some pictures when I get time. You have to get a couple of connector contacts from your dealer. Insert them in connector M66 behind the dash and make your own harness. It does require soldering etc. Mine works great!
Does your car have the navigation package?
Old Apr 22, 2009 | 11:53 AM
alti35's Avatar
alti35
Looks kinda long, haha.
Old Apr 23, 2009 | 03:35 PM
LightningG37's Avatar
LightningG37
nope....
Old Jun 26, 2009 | 03:24 PM
Blue37's Avatar
Blue37
Originally Posted by alti35
What connectors do I need and where is this M66 conector located???
alti35 or rmw00: My 2009 G-37 Journey does not have the harness in the steering column so I believe I need to get to the M-66 connector. Problem is I can't access the flickr site as it is listed as private. How can I get the details on how to wire in these shifter paddles?
Old Sep 16, 2009 | 01:56 PM
redG37sedan's Avatar
redG37sedan
Here are the pictures: http://www.flickr.com/photos/rmw00/s...7614971013297/
You can also go here to download the Infiniti tech manuals:
Infiniti Publications
Hi rmw00, the photos you posted via flickr are not visible because they are not open to the public. Can you change that so they are visible?
I'm interested in possibly making the same modification on my 2009 G37 Journey sedan.
Thanks.
Old Nov 12, 2009 | 08:51 AM
LightningG37
Here are the pictures: Infiniti G37 Paddle Shifter Install - a set on Flickr
Holy Crap! You are my new hero..I'm so stoked to do this mod thanks so much for posting it..my only regret on the car was no paddles..couple of questions..
1. Is see on the M66 end of your harness, there are 3 wires, M66 connections and a ground..on the other end there are 2 pairs..at some point did you split the ground for the 2 connectors?
2. Why did you introduce those PN56210 red connectors at the end (as opposed to just running the 2 wires all the way to the paddles)?
3. The "hot melt glue" you used on the paddles, is that just like a craft hot glue gun or is that a special electronic glue?
Thanks thanks thanks!
Old Mar 31, 2010 | 03:03 PM
LightningG37
For those of us without pre-wired Gs
Okay, I gave up on this for a while b/c I couldn't find the terminal connectors for the M66 harness connector. I just tracked down a distributor for these little connectors but the minimum purchase is 84 @ .60 cent a piece . I was wondering if there was anyone else looking for this who might want to go-in on this purchase?
Old May 12, 2012 | 04:47 AM
mb2zj2's Avatar
mb2zj2
Hi all. It seems that I am very late to this thread, but I am looking for some information on adding paddles to my non nav journey coupe. I see that it has been done, but the pics on Flickr are kinda vage... no offence as I appreciate them for what they are, but with the wires being twisted, as I would do myself, the general path of where the wires go, gets crazy to follow. I am a master mechanic, and do not require much direction, but I would like to see a wiring diagram of the added harness. Can anyone help me, and possably draw up a quick one? Even a quick skech is all I need, and within an hour, I will be elbow deep in the dash, kill in this mod. I will take hi def pics, and post a full "how to DYI" complete with wire diagrams, part #'s, prices, and vendors lists for all to use. Please help me, so together, we can help everyone who wants paddles in there base or journey g37 coupe.
Old Sep 18, 2013 | 12:06 PM
lechner80's Avatar
lechner80
I'm looking for the same info, Just installed the paddle shifters to my 2010 G37 vert. w/nav and tech. But found NO WIRES TO HOOK IT UP! Help Please
Old Sep 21, 2013 | 11:47 AM
lechner80's Avatar
lechner80
rmw00 Can't find those pictures? Are they still there? Thanks John
Old Nov 24, 2013 | 11:56 PM
mb2zj2's Avatar
mb2zj2
BUMP! Has anyone tried this mod, and have any info regarding the install? The pictures are not visable anymore, so please, someone, help!
Old Nov 25, 2013 | 11:13 AM
lechner80's Avatar
lechner80
Yes I have complete this mod. The wiring is easy. The install is very difficult if there is NO WIRING. I will be glad to help. Step One go to a junk yard to get the wiring. Get the plug with the wiring from M66 and the plugs with the wiring at the paddle shift. WHEN you have this let me know.
Old Jan 16, 2019 | 04:33 PM
1slowG37's Avatar
1slowG37
Do you guys have pictures of the m66
Old Jan 16, 2019 | 04:38 PM
  #29
1slowG37's Avatar
1slowG37
do you have pictures of the m66 and does it need to come from G37 only
Old Jul 8, 2021 | 04:49 PM
  #30
Oscar Zejdlik's Avatar
Oscar Zejdlik
Can you send me a private message on how you got your paddle shifters to work on your 08 g37 journey without the wiring harness? I too have an 08 g37 journey and discovered I do not have the harness
