Clutch dead at 6.3k miles
Old Jul 23, 2008 | 11:55 AM
flux303's Avatar
flux303
Just found the TSB for reinitializing the windows. Guess I should read the forums first Hopefully that'll fix the window problem and I'll be back in business with my G.
Old Jul 24, 2008 | 07:33 PM
ppc's Avatar
ppc
Actually it's the slave cylinder for the clutch, the master cylinder is in the brake system but close.
There are master cylinders in both the braking system and clutch system, basically attached/activated by the pedals. In the clutch system the slave cylinder is called a CSC (Concentric Slave Cylinder). It translates the hydraulic pressure generated by the clutch master cylinder into corresponding movement in the CSC operating the clutch. It is located in/on the bellhousing. In the braking system, the slave cylinders are the pistons in the calipers.
Old Jul 24, 2008 | 08:43 PM
jtree007's Avatar
jtree007
Yes sir!
For there to be a slaver cylinder there has to be a master to make it move
Old Jul 24, 2008 | 10:08 PM
greggv's Avatar
greggv
there is a master cylinder for the brakes, which works the calipers, and a master cylinder for the clutch, which works the slave cylinder.
Old Jul 31, 2008 | 03:15 PM
DanMardik's Avatar
DanMardik
Glad to hear you're back on the road.
Old Aug 23, 2008 | 04:52 PM
Budakai's Avatar
Budakai
My 370gt/g37 has 7500 miles on it and the clutch is fine. Your clutch master slave cylinder is bad, this happens on my honda prelude every year. If it goes bad again just carry it in right away so you won't get stranded on the side of the road. I hope everything went well for you after that Sir. Thanks.
SS2006
Aug 27, 2024 07:33 PM
abretz89
Aug 20, 2015 11:58 PM
Cr0tchf4i
Aug 19, 2015 03:52 PM
Digilog
Aug 17, 2015 03:54 PM
Thirty_Seven
12
Aug 16, 2015 01:48 PM
