GT Motorsports: G37S VHRTT, GTM HR Turbo Kit, FCon VPro, Stock Block Testing
From what i've heard.
Both share very similar platforms, in fact, check out pictures of the GTR engine bay and ours... the only difference one can spot is the dual intakes being for turbo app of course and the engine cover being different, other than that everything looks exactly the same... and every other part is in the same place.
Check out the pictures of the engine by itself on the GTR and it will actually look very similar to what GTM is doing.
g37 seems to have been molded to use the GTR AWD Tranny as well.
Anyway, all this is info i've gathered from a few other forums and info shared in other places. I haven't and i don't believe anyone else has actually had the opportunity to check if it bolts on to our tranny or if the engine mount are placed the same way.
Basically if the tranny bolts on, its done deal. Getting the 2 ecu to work together should not be too difficult, i've done it a couple time with the 2jzgte.
Gtm Tt
Finally it is out!
If we take on consideration what we are getting for $15,000, installation by one of the best installer/tuners (GTM), plus a kit using QUALITY PARTS!!!! this is a GOOD DEAL!!!!.
My problem is that I am in Florida, does anyone know how much is to send the a G37 from Orlando/Florida and back??
Gspot
Gspot
Finally it is out!
Gspot
Gspot
Yeah, for the amount of fab work that goes into the Two manis and charge piping etc.. Sounds about right..
Finally it is out!
Gspot
Gspot
GTM along with the other major shops usally will ship your car for you on a build. Not sure how extensy the build must be. Might need to call on that. Not sure if they still offer it, but they did at one time. But you could always just order the parts and have someone here on the east coast install it. You have Forged Performance, which I know Sharif has had a long running with GTM. Shouldn't see why the labor would be any more here.
Gspot
from what I've read it should be. In fact it seems there are a lot more similarities between the 2 cars than most people know about. Probably the reason they've been able to keep production cost so low.
