GT Motorsports: G37S VHRTT, GTM HR Turbo Kit, FCon VPro, Stock Block Testing
Old Jul 3, 2008 | 04:49 AM
  #346
Sam@GTM's Avatar
Sam@GTM
SAM
GT MOTORSPORTS
Old Jul 3, 2008 | 04:54 AM
  #347
Sam@GTM's Avatar
Sam@GTM
Originally Posted by JanSolo
So what does the FCON manage then? Just ignition timing and air/fuel? The reason I ask is because I am not very familiar with it, but I have seen a number of people using the AEM EMS and once you use that, you lose just about every creature comfort in the world as AEM assumes that if you are going to replace the OEM ECU, then you're clearly making a full time track car. I would assume based upon this that either the FCon Pro is in used in addition to the OEM ECU or HKS cracked the Infiniti ECU and can manage all the stock features. The latter doesn't seem realistic to me, so I would assume that the FCon is clearly only managing the engine which would make it seem like it's acting akin to a piggy back.
A couple points that need to be addressed as well.
1. Passing smog is going to be just about impossible in California with this kit on, unfortunately. Luckily, you have many years before you have to smog it here. But, as long as you don't have to pop your hood if a cop pulls you over, you'll be okay, or else it's most likely going to be a visit with the state ref. With that exhaust, you're screaming for police attention. So, let's say someone wanted to run the stock exhaust system, any guess on how much lower whp numbers are going to be?
2. Gas mileage is going to go down moreso with this kit. You guys didn't increase injector size and toss out the stock fuel pump for fun, so it has to be assumed that MPG is going to get worse. Any theoretical numbers on this?
3. The numbers you guys achieved, I assume, is on 91 octane. On higher octane gas, such as 92, 93, 100 and C16 or with water/meth injection, you can obviously run more timing, less fuel - so would you guys happen to have any whp numbers with fuel other than 91 if that is in fact what you used to achieve those numbers?
4. The turbos you guys are running are not big and I assume it's because you want to have smooth boost characteristics (eg: not running a 42R on a 2 liter which equals massive lag and a true test of patience). So this begs the question - when does peak boost hit? Is there any boost taper/climbing or are you running 8psi flat until redline? Run into any surging issues with this turbo?
5. Are these numbers with or without cats?
And I'll skip the question about weight distribution being altered due to the heavier front end due to the turbo kit and lighter rear due to the swapped exhaust system.
Thanks in advance and I hope I'm not pestering you guys with too many questions.
I have to catch some sleep i will answer all your questions next time on the forum .
SAM
GT MOTORSPORTS
Old Jul 3, 2008 | 08:09 AM
  #348
lin's Avatar
lin
Originally Posted by SAM@GTM
SAM
GT MOTORSPORTS
drool.......
Old Jul 3, 2008 | 12:03 PM
  #349
Mrbig19's Avatar
Mrbig19
Im not seeing the price installed, how long will it take.....
Old Jul 3, 2008 | 12:36 PM
  #350
Buddy Revell's Avatar
Buddy Revell
Looks great, Sam! Does this use the same piping and hardware as your 07-up 350Z kit? http://www.my350z.com/forum/showthre...=369581&page=5 . The design looks alot cleaner/better than what I've seen from other companies working on the HR engines. Keep up the great work!
Old Jul 7, 2008 | 12:37 AM
  #351
trebien's Avatar
trebien
Geez, that's a lot of metal.
Old Jul 7, 2008 | 01:23 AM
  #352
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
SAM
GT MOTORSPORTS
I think you need to let Sharif slap this on my car so I can rep the east coast with this kit !!
Old Jul 7, 2008 | 02:53 AM
  #353
Dipstix6996's Avatar
Dipstix6996
Tenn is not the east coast. Im on the east coast so it goes on my IP G
Old Jul 7, 2008 | 03:09 AM
  #354
]\[ /-\ ]\/['s Avatar
so who in houston wants to install and tune this kit for me?
kit looks awesome
Old Jul 7, 2008 | 08:57 AM
  #355
weave's Avatar
weave
Nah, Maryland has a TT G already (Fireboy). We need someone to represent in VA and my PG 37 would be a perfect choice!!!
Old Jul 7, 2008 | 09:00 AM
  #356
weave's Avatar
weave
SAM
GT MOTORSPORTS
So Sam, this kit price includes all the parts in the picture but what about an EMS? Is that extra?
Old Jul 7, 2008 | 11:17 AM
  #357
terrycs's Avatar
terrycs
Yes, you'll need EMS and fuel system upgrade. Check out the details on their website. There are other items that they offer for the kit.
Old Jul 20, 2008 | 11:39 PM
  #358
MMC Racing's Avatar
MMC Racing
Any chance you are going through CARB certification on this kit?
Old Jul 21, 2008 | 12:00 AM
  #359
terrycs's Avatar
terrycs
Probably not because 1) Not enough people buy these to justify the cost of agency testing and 2) from what I've heard, JWT tried real hard at one time to certify a TT and was never successful.
Old Jul 21, 2008 | 12:04 AM
  #360
MaxToTheG37
Fireboy lives in VA
