Can Someone Post a D.I.Y. Oil Change for G37
Old Jun 23, 2009 | 11:44 AM
  #46
KnoxvilleG37's Avatar
KnoxvilleG37
Well I'd think with our debris shield that covers our oil pan and oil filter, this would be less likely of a problem, right? Especially for those of us that don't track our cars?
Old Jun 23, 2009 | 11:54 AM
  #47
UNV-IT46's Avatar
UNV-IT46
i dont know. My S2000 had an undertray on it already. but i assume if your not tracking the car and its not low(my s2000 was on the ground) then you should be ok. but i have still heard a fair amount of bad stories that i wouldnt trust it ever again. i'll stick with a bolt. just changing to a magnetic drain bolt to help eliminate any debris
Old Jun 23, 2009 | 02:51 PM
  #48
It's been a while since I changed my oil on the G, but isn't the oil drain plug situated on the side (somewhat) of the oil pan at the bottom? For you to shear off the plug, wouldn't you have had to completely bottom out and smash up your oil pan? If that's the case, the drain plug is the least of your worries.
Old Jun 23, 2009 | 03:08 PM
  #49
DashKid's Avatar
DashKid
Yeah the plug should be on the side.
Changing oil is very easy. I had to do it for a while when I had my G very lowered that it wouldnt fit on the stealerships lift.
Old Jun 23, 2009 | 03:19 PM
  #50
UNV-IT46's Avatar
UNV-IT46
i didnt do anything to my G. it was on my S2000 which was on the bottom and straight down.
Old Jun 23, 2009 | 03:51 PM
  #51
Gotcha. I misunderstood and thought your issue was on using the Fumoto on the G.
Old Jun 23, 2009 | 04:04 PM
  #52
UNV-IT46's Avatar
UNV-IT46
oh no. i wouldnt install the fumoto again on any car honestly.
Old Jun 23, 2009 | 04:06 PM
  #53
To each his own I guess.
Old Sep 13, 2009 | 07:50 AM
  #54
g37musings's Avatar
g37musings
I have used Fumoto valves on my cars for years, including my lowered Miata and have never had an issue.
Old Oct 19, 2009 | 08:13 PM
  #55
pauliewalnutzz's Avatar
pauliewalnutzz
how many quarts do you gotta put in? 5?
Old Oct 19, 2009 | 10:41 PM
  #56
js3350z's Avatar
js3350z
^^I believe 5 1/3 if I remember correct from last weekend
Old Oct 19, 2009 | 10:51 PM
  #57
hispeed-lowdrag's Avatar
hispeed-lowdrag
yeah it'll be between 1/3 and 1/4 but if you just go a little more and put 1/3 in it wont hurt
Old Oct 20, 2009 | 09:14 AM
  #58
pauliewalnutzz
So its 5 1/4 and its 5w30 oil right? 09 g37x. Thanks guys
Old Dec 4, 2009 | 06:50 PM
  #59
vinnys coupe's Avatar
vinnys coupe
Bumping this thread, just had my 5th oil change at 22600, and my Service Engine Light is still on? How can I remove it? I reset all my settings and its still on.
Thanks
BTW I also use 5w30 mobil 1 synthetic.
Old Dec 4, 2009 | 09:39 PM
  #60
js3350z's Avatar
js3350z
Thanks
The service engine light will not come on for an oil change... you will get a maintenance reminder that you have to reset. but the service engine light shouldn't come on for an oil change interval
