Clutch problems???
Old Nov 3, 2007 | 09:53 PM
brrrtpoypoy's Avatar
brrrtpoypoy
Exclamation Clutch problems???
Is anyone out there experiencing any problems with the clutch? I just picked my IP G37S last Tuesday and tonight I noticed that the clutch creaks when engaging a gear (mostly 1st and reverse). It occurs when I have to engage the clutch when backing into a stall or my garage or when I put it in 1st but have to maintain a slower speed (you know when you're in rush hour bumper to bumper traffic). It also smelled like something was burning, i hope it's not the clutch (I don't ride my clutch).
Hope this makes sense to you guys, just want to know if anyone has experienced soemthing similar and if so, what was the problem? Did you have to take it back to the stealership?
thanks in advance.
Old Nov 3, 2007 | 10:13 PM
UNV-IT46's Avatar
UNV-IT46
thanks in advance.
Odd i dont have any noises coming from my clutch. But you should not be smelling burning clutch. If you smell something odd burning its usually one of two things, you over heated the brakes and you get that burnt glazzing smell, the other is the clutch being burned up...
Old Nov 3, 2007 | 10:17 PM
CHI-TOWN G37's Avatar
CHI-TOWN G37
My car stunk like crazy for a few days while all the manufacturing jizz burned off, but that is typical and to be expected. Hopefully, that is the source of your smell. The clutch noise...better get that checked right away. Drive it back asap. Good luck!!
Old Nov 4, 2007 | 04:50 PM
brrrtpoypoy
I found a solution to the clutch problem I've been having
I couldn't wait to bring it in to the delaership so I decided to just see if I could figure out what was wrong. I just used some WD40 to lube up the components of the clutch inside the car and voila, creaking sound was gone!
Hope this helps anyoine else that might encounter the same problem.
BTW, I absolutely L-O-V-E this car!!
Old Nov 4, 2007 | 11:18 PM
Motor25's Avatar
Motor25
Which components exactly?
Old Nov 4, 2007 | 11:53 PM
DetroitG37Joe's Avatar
DetroitG37Joe
Yeah which compononents...I wouldnt mind throwin a lil WD 40 on there just to be preventive.... Can U explain in detail and how u got to the components...If possible w/pics....Thanks a mil..
Old Nov 5, 2007 | 09:52 AM
brrrtpoypoy
Alls I did was go under the footwell where the pedals are, depressed the clutch with my hand just so I could see which parts moved and lubed those up, pretty simple.
Old Nov 5, 2007 | 01:32 PM
]\[ /-\ ]\/['s Avatar
yea...i have the same creak noise...gonna give it some WD40 too
Old Nov 5, 2007 | 02:39 PM
NJlakeshoreG's Avatar
NJlakeshoreG
maybe lithium grease instead of wd40 might work better?!?? wd40 can attract a lot of dust and build grime..
Old Nov 5, 2007 | 03:32 PM
DetroitG37Joe
oh ur talkin about a creak from the clutch PEDAL itself? Phew. I thought u were talkin about clutch components/parts from under the hood, something internal....
Old Nov 5, 2007 | 04:54 PM
IP37's Avatar
IP37
get the same noise here
sounded to me like it was outside the firewall though. i'll give this a try later and see
Old Nov 5, 2007 | 06:09 PM
NJlakeshoreG
i heard it on a car in the showroom...i guess it could be somewhat annoying..
Old Nov 6, 2007 | 02:35 PM
trendy26's Avatar
trendy26
Noticed the same thing. Taking to dealer in a couple days. Guess it's somewhat normal if it's happenieng to all of us....
Old Nov 6, 2007 | 02:36 PM
trendy26's Avatar
trendy26
Dont think its bad
stevo4756
Oct 9, 2015 01:54 AM
butwhatuptho
Oct 4, 2015 07:51 PM
MrRiv
Sep 29, 2015 04:59 PM
k19g37x
Sep 29, 2015 02:46 PM
r0cketm0nkey
Sep 27, 2015 01:34 PM
