Tips for driving the 5AT & minimizing delay in downshifting
Super Moderator of Pwnage
Here are some things that I have observed when driving in manual mode. As you are aware there is a delay when the car rev matches. I have tried some different driving techniques and I have found one that in most driving situations completely eliminates the delay on downshift.
-When you want to downshift into 1st or 2nd gear and intend to accelerate:
- first engage the gas pedal then use the selector to downshift. This eliminates the delay- the car will simply engage in gear, rev up and go.
The delay occurs when you lift throttle and downshift.
As long as you engage the gad pedal before selecting the gear, the car will engage immediately into the desired gear.
If you do not intend to accelerate then just let the car do it's thing.
I have not experienced the delay at all when downshifting into 3rd gear. I think that it is mainly a 3-2 and 2-1 issue.
Another thing I have found via experimentation:
If you are in D mode you can still manually control the gears if you have paddle shifters. Just press up or down on the padles and the car will shift according to your command even though it is in D mode. After about 5 seconds it will automatically go back into D mode.
Thanks for the info.
A couple things I've noticed when using manual is that there isn't a lot of power in 2nd gear. As soon as I go from 1st to 2nd, the RPMs stays relatively high I would have to shift up to 3rd only a few seconds later.
Another thing is when I'm cruising its hard to tell whether I'm in 4th or 5th gear and when I downshift I wouldn't know if i'm gonna go to 3rd or 4th. Any tips or do I just need to get used to the feel of the car.
i've noticed that going from D to DS, while at speed, will always drop you one gear. so let's say you're on the freeway at 75. if you swap over to DS, you're now in fourth. if you pull back, now you're in third at about 5500 -6000 RPM for max torque.
here's what i do if i'm on the freeway and want to drop two gears or just on a surface street and want to drop two gears:
when you have your hand on the shifter, ready to apply a leftward motion, apply a backward pressure to it as well. what this will do is, as soon as it's over in DS, it'll downshift one gear. if this is down fluidly enough, you'll go from cruising in 5th, to screaming in 3rd and ready to nail it.
What mph are you auto guys topping out in 2nd gear? Are you guys having to shift three times before 60? I just noticed yesterday (playing around) that I was able to top out 2nd gear at 65mph. That's insane, eliminating the third shift before 60 allows for better 0-60 performance. just curious.
Not really, I am asking them to tell me what their max speed in 2nd gear is in the G37S Auto.
