1st oil change before 3750 not recommended?
Old Oct 20, 2007 | 10:46 AM
dmkozak's Avatar
dmkozak
Originally Posted by Motor25
If you change your oil before 3750 miles, your engine will blow up into a thousand pieces!
In all seriousness though, if you change your oil before 3750, nothing bad will happen. It's probably better that you do, because you'll get all those tiny metal particles out of your engine
But, you do not know this to be true. (Not that actual true knowledge or facts are a requirement for posting here. But, the lack of same only confirms the "stupidness" of a number of posters.) It is possible Nissan has included a break-in additive to the Factory fill. Honda, for example, does publicly state this. Nissan, though, is silent on this issue. I have not been able to learn anything about what might or might not be added to the conventional 5W-30 Factory fill. No source has been able to tell me they know for sure one way or the other.
So, if the Factory has included a break-in additive, then you should definitely not drain that oil before 3,750 miles (actually, the "real" number is 6,000 kilometers). And, if they haven't included anything, and they say it's okay to leave it in for 3,750 miles, then what is the harm?
Old Oct 20, 2007 | 10:56 AM
dmkozak's Avatar
dmkozak
Originally Posted by UNV-IT46
no 3750 is the early oil change if you read the book the max or normal one is like 7k and change. ....
Sorry, while I don't have it in front of me right now, I read it carefully a few days when discussing this with an oil company engineer. The 3,750 mile oil change interval is for stop-n-go driving, extreme temperature driving, short trips, towing, etc. The 7,500 mile change interval is for temperate temperature constant speed highway driving.
While some people tend to drive mostly on open highways, I am not one of them. Based on the Service and Maintenance Manual, I should be a 3,750 mile changer (to keep the Factory warranty in effect). As a 3,750 mile changer, pure synthetic might be a waste of money (even in Phoenix summers), and 5W-30 semi-synthetic should be more than okay (at least according to my oil company engineer friend). Also, because the Factory says 5W-30 conventional is acceptable for high heat desert climates, semi-synthetic should provide even better lubrication in temperature extremes and for more miles than conventional.
Old Oct 20, 2007 | 04:34 PM
UNV-IT46's Avatar
UNV-IT46
Originally Posted by NemesisG37
So how much experience do you have with the new G37 engine? Seems like you know everything about it.
well the only experience i have is the 850 miles on my car right now. But considering i own my own shop and all we work on is japanese and european cars i have a lot of experience working on motors. Again like stated i dont have tons of time with the VQ37 but i do have A lot of experience with VQ motors...
Old Oct 20, 2007 | 04:37 PM
UNV-IT46's Avatar
UNV-IT46
well i really could care less what some oil guy says. He didnt design the motor. So his opinion on what oil is best for a motor he knows nothing about means squat to me. Infiniti says not to switch to syn until like 15k miles. You really shouldnt switch any motot to syn before 15k miles because the compounds of each oil are very different. You can destroy the seals by switching to syn.
Old Oct 20, 2007 | 07:00 PM
dmkozak's Avatar
dmkozak
Wow. A little hostile are we? Actually, this engineer is the oil company's liason with manufacturers to make sure his company's products comply with the manufacturers' specific requirements. (You know how BMW, VW/Audi and others have their own oil spec requirements.) So, he has first hand access to the engine developers. You may not want to believe this but his knowledge of pretty much all currently produced engines is first hand. That is his job. He has the detailed internal specs for virtually all currently produced engines.
Actually, while this information has been passed from factory personnel to NNA tech personnel to dealership personnel, it is not official. Infiniti has never made or released any public statement about synthetic oil.
Old Oct 20, 2007 | 08:04 PM
NemesisG37's Avatar
NemesisG37
So what is the conclusion...First oil change right after 1500 mile break in or at 3750?
Old Oct 20, 2007 | 08:47 PM
UNV-IT46's Avatar
UNV-IT46
ok i'm not driving a bmw, vw, or audi.all those cars come from the factory with full synthetic.thats completely different. Its an infiniti. and does not come with synthetic And while i was talking about the g37 its a well known fact not to change oil to syn in a motor that does not come with it before 15k+... any motor
Old Oct 20, 2007 | 09:02 PM
dmkozak's Avatar
dmkozak
I think you don't get it. His job is to make sure his company's oils are acceptable to the manufacturers. That BMW, MBZ, Porsche, VW/Audi, etc. happen to publish their own specs was just an example. Believe me or not, but this man knows more about what oils work best in which engines than anyone, except his counterparts at other oil companies.
Since some engines come with synthetic factory fill, this, obviously can not be a well known fact. Also, since some manufacturers say it is okay to change to synthetic at delivery, again, this can not be a well known fact. Toyota says their engines can all be run on synthetic at any time. They only use conventional as a factory fill for simplicity's sake (and, probably, it saves them money).
I would prefer to discuss, rather than argue with someone who has to be right, so I will leave this post.
Old Oct 20, 2007 | 10:00 PM
UNV-IT46's Avatar
UNV-IT46
as i stated you should not switch to syn in motors that dont come with it from the factory. I didnt say anything about ones that comes with full syn already.
Old Oct 24, 2007 | 06:21 PM
ABQG35c's Avatar
ABQG35c
Originally Posted by Flyingcesar
I have had four new cars and with all of them I do what the manufacture recommends… So for the G37 I’m going to change the oil at 3750.
Yeah they also recommended that we pay around $4k more for our cars too so that can all be profit to them, and do we? NOOOOO
Old Oct 25, 2007 | 05:38 AM
Xander's Avatar
Xander
I got my oil changed yesterday at 1800km's the dealer I purchased and will be servicing my vehicle said not to switch until 6000km's as there is a special additive in the oil that was in the engine, and will be in the oil change I just had completed.
viper630
Sep 23, 2015 09:30 AM
sharmelan
17
Sep 14, 2015 03:18 PM
si_driver
Sep 13, 2015 12:04 PM
inspector94
Sep 8, 2015 12:57 PM
