ECU Tuning / Dyno Data This subforum is specifically aimed at ECU Tuning reviews, questions, dyno charts, etc..
New Dyno !!
Old Mar 7, 2019 | 11:36 PM
zer099's Avatar
zer099
Question is: what restriction causes that in our engine? Head, exhaust, both?
OP, the 3.5 plenum comes from the HR engine. It's pretty much the same plenum but it has slightly longer runners which translates to better mid range (read: under the curve) power. It was first sold by companies as a M370 intake i believe. It does have a slightly different mounting pattern so it is not a direct swap, but it's not a hard mod to do on your own if you have the tools, time, and knowledge. Some people have dyno data that shows a steeper drop off in power in the higher RPMs. I didn't have that at all, and as you can see with chuckie311, neither did he; but it still remains a debatable topic. Hence the question that was posed if you had one due to the appearance of the rather quick looking drop in power you have above 6.5k; but it's not really that odd of a drop after closely examining.
You have a good engine and making good power, go tear up the strip and post up your slip!
Old Mar 8, 2019 | 09:28 AM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
Not sure why you want to have TQ in the upper RPM's that's where you want more Horsepower to be
Old Mar 8, 2019 | 10:38 AM
slartibartfast's Avatar
slartibartfast
As has been stated, HP is a function of torque and rpm. The more torque you make at a given rpm, the more HP you get. If your torque drop past peak is less than the next guy, you're engine will make more HP. It's that simple.
Old Mar 8, 2019 | 10:40 AM
sundevil73's Avatar
sundevil73
I'm fine with it. It was brought up by people that have yet to do anything to their cars. I will see how it performs soon!!
Old Mar 10, 2019 | 02:23 PM
qmantran's Avatar
qmantran
Originally Posted by sundevil73
. My stock numbers were 268whp/238tq before the FBO. ACTUALLY, have been told my engine is strong, Moncef (admin tuning), tunes a lot of VQs , similar mods my G HAS+8WHP then any other NA FBO G37.
Wow you went from 268 -> 331whp
that's +63whp increase.
I mentioned in another thread that you could gain +50whp with nearly the same bolt ons you had and chuckie311 was in disbelief. You have headers and gained +63whp total. Impressive.
Originally Posted by chuckie311
baisc mods..cold air intake exhaust HFC + tune is around 3.2k for what 20-30whp..and thats if you install it yourself
Originally Posted by qmantran
admin tuning intakes and his tune alone nets you +20whp..
Admin intake - 640
eps pcv delete - 130
ISR test pipes - 170
ISR y-pipe - 220
y-back exhaust - 600
tune - 850
$2600 total. You can sub the expensive Admin intakes for other intakes which are $100 cheaper and doesn't require a PCV delete kit to save over $200 bringing total cost to $2300-2400.
those are basic bolt ons that most people can do themselves if they have access to tools and a floor jack with stands.
All of that will put you close up 320whp. A stock g37 is around 270whp.
+50whp for ~$2,500
no way in hell your gaining. 50whp with those mods...
you better go to the dyno sections and read up..
dynos numbers don’t mean **** since they all read differnet..
you want real numbers go to the track.
I know a guy with a admin tuned g37 sedan that ran 13.1 on 19" coupe wheels.
There was a admin tuned 370z that ran 12.5 n/a all motor that same day.
There's also a all motor g37x sedan owned by Matt that ran a 12.6. I believe you are definitely capable of 12s
travis@forged
SouthEast
Jul 17, 2010 10:29 AM
C@ciQ
Intake and Exhaust
75
Jan 10, 2010 11:33 PM
G2Envy
Intake and Exhaust
Sep 30, 2008 11:39 AM
MaxToTheG37
Intake and Exhaust
59
Sep 4, 2008 12:45 PM
