Lc2i install help
Old Dec 1, 2019 | 11:28 PM
SquadRobo's Avatar
SquadRobo
Exclamation Lc2i install help
I have read a lot of forums and also looked the wiring diagram up for my 08 g37s coupe with Bose and nav. I used 23-26 I have good power and my amp cuts on but I don't have any sound. The lc2i light comes on when I jump from power to remote but it's set to signal sense. Any ideas what my issue is? Thank you for your help
Old Dec 3, 2019 | 06:20 AM
Surfnazi's Avatar
Surfnazi
What gain setting is lci
Old Dec 3, 2019 | 08:19 AM
SquadRobo's Avatar
SquadRobo
I had set it in the middle
Old Dec 3, 2019 | 04:35 PM
SquadRobo's Avatar
SquadRobo
I set my gain midway. But I tried it at mine and max and nothing.
Old Dec 4, 2019 | 03:29 PM
Surfnazi's Avatar
Surfnazi
You sure you tapped right signal else lci could be bad
Old Dec 4, 2019 | 04:04 PM
SquadRobo's Avatar
SquadRobo
Yes I tapped the right signal wires. I used the blue quick connection but think I might have to get some of the red ones because they are smaller and the wire is small. If that doesn't work then the LCI is bad. What do you think?
Old Dec 4, 2019 | 04:46 PM
Surfnazi's Avatar
Surfnazi
Lci go bad new it happens I'd replace it first if you're going to have to retap wire esp if lci is still under warranty. Btw what amp are you using and is it set to the right setting for low pass?
Old Dec 4, 2019 | 06:50 PM
SquadRobo's Avatar
SquadRobo
I'm using a kicker amp and kicker subs they are set right as well.. I'm going to send it back and get another one and hopefully that will fix it if not I'm not sure what my other options are besides going to a shop and I don't really want to do that.
JakeG37
Aug 12, 2015 08:49 PM
dsolis
Jul 7, 2015 07:07 PM
Lunchbox89
Aug 27, 2014 11:36 AM
tadmac
Feb 27, 2014 05:14 AM
