Help 2013 g37x sedan w/boss amp install but no sound?
Old Jul 2, 2015 | 12:52 AM
dsolis's Avatar
dsolis
just finished my amp install. On my 2013 g37x sedan w/boss. I followed https://www.myg37.com/forums/members...eigerwald.html steps and I don't have any sound going to the sub I tapped into harness b41 #s 23-26 and #22 for remote I tried with a LOC and straight tap with no luck any help or suggestions will be really appreciated
Aslo This isn't my first install. Just my first with boss system
Old Jul 3, 2015 | 12:29 PM
CRiME's Avatar
CRiME
Is the amp not powering on, or is it powering on but no output? I used wire #20 for the turn on signal. If the amp is powering on properly, make sure that the polarity wasn't switched when tapping the RCA wires in. It's also worth mentioning that I had no sound with the wire taps either, and the amp would not turn on. I ended up cutting the wires and soldering in the RCA's and remote signal. After that, everything was fine. I tried the red taps and also the blue taps, neither worked. I'm not sure what the issue was, I just assumed I had a bad set of wire taps.
Old Jul 3, 2015 | 11:14 PM
dsolis's Avatar
dsolis
Thanks for your help CRiME. The amp powers on just have no output. How would I check if the polarity was switched? I'm going to have to solder the wires and hope that works!
Old Jul 4, 2015 | 01:24 AM
dsolis's Avatar
dsolis
Well I just finished soldering the wires and nothing still no output
Old Jul 4, 2015 | 07:50 AM
CRiME's Avatar
CRiME
You can verify polarity if you have a multimeter, but once you've stripped your RCA cable, just check to make sure that the positive half of the RCA cable connects to pin #24 for the left side, negative to #23, and the positive half of the other RCA cable is connected to pin #26, negative to pin #25 for the right side. Since you've done installs before, you probably have it correct, but sometimes it can be easy to mix up these small things - especially when working with such a cramped harness.
If the connections check out OK, I would investigate the amp next - do you have a different camp that you could try?
Old Jul 4, 2015 | 11:56 AM
dsolis's Avatar
dsolis
I checked all my wiring and made sure it was correct before I soldered the wires I guess I'm going to buy another amp
Old Jul 7, 2015 | 07:07 PM
dsolis's Avatar
dsolis
UPDATE: so today I went to a audio shop to troubleshoot my issue turns out that the amp Is no good. But I noticed that the guy from the audio shop disconnected where I tapped into harness b41 and he tapped into the harness that goes to the bose sub is that a safe place for signal or to tap into?
G's
Nov 5, 2023 12:01 PM
SLEV3N
General Tech Questions
Oct 17, 2015 05:58 PM
sharmelan
Aug 25, 2015 03:41 PM
Spicy_Kimchee
Aug 11, 2015 09:10 AM
