DIY for oxygen sensors? upstream, right side
Old Nov 17, 2012 | 02:50 PM
fast_coupe's Avatar
fast_coupe
Question DIY for oxygen sensors? upstream, right side
Is there a DIY for upstream 02 sensors??? I tried searching every page of this section for "sensors", just found 1 unrelated post.
i have got this so far to go on..
Last edited by fast_coupe; Nov 26, 2012 at 12:02 PM. Reason: 90 views and no replies?
Old Dec 20, 2012 | 11:15 AM
mystikal's Avatar
mystikal
are you trying to replace it? Im not sure which one this is (either the one before the cat, or after towards the rear)
Speaking from past experience, I think you'll need to remove the cat for easier access to the sensor (if its the one before the cat), try getting a swivel, or small wrench...and I believe the plug should be in the engine bay..
Old Dec 20, 2012 | 03:46 PM
fast_coupe's Avatar
fast_coupe
good point, yes i should specify this is for replacement.. I've been told by a dealer that it's the upstream right side / passenger side sensor and is indeed allegedly before the cat.
I've gotten a little advice since my post,.. one guy said i should do this sort of thing with the car slightly warm, allegedly so i don't strip or break anything and to use some PB Blaster spray, then twist once clockwise and then counterclockwise.. but i don't like spraying anything onto hot surfaces, makes me nervous. i'll try a swivel or small wrench tho thank you
Old Dec 20, 2012 | 04:16 PM
mystikal's Avatar
mystikal
yea i would try to start the car, and let it sit for a couple of minutes since your probably in a cold air...most likely it will not strip...Not too sure about the counter clockwise, the clockwise...I would just remove it instead of placing too much tension on the blots thus cause it to strip/break... but it shouldnt be too difficult to remove...Good luck
Victory
17
Oct 27, 2022 03:45 PM
04G35NYC
Dec 24, 2015 01:00 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
harlemcat45
Sep 9, 2015 09:35 AM
