Help: Hareness Removal
Old Feb 24, 2012 | 11:09 AM
Alan318's Avatar
Alan318
Press down on the tab and you'll hear a small click, while maintaining that pressure pull it apart. Dont be gentle with it or itll never work. ALSO remember to cut the zip ties that holds the plastic wrapped bundle of wires the metal harness attached to your light. I uninstalled the metal bracket since it no longer served a purpose.
Old Feb 24, 2012 | 11:23 AM
soolman32's Avatar
soolman32
Use a small screwdriver to push the tiny tab down and pull.
Old Feb 24, 2012 | 11:46 AM
Alan318's Avatar
Alan318
Been tryin for the past 3 hours the tab is all deformed and knicked now. FML
Old Feb 24, 2012 | 12:31 PM
soolman32's Avatar
soolman32
Are you pulling on the harness as the tab is pushed in? That's all I had to do for mine. Also if this is your first time ever taking the lights off the car, there is a white zip tie holding them down you'll have to cut.
Old Feb 24, 2012 | 07:36 PM
Alan318's Avatar
Alan318
Got it! Thanks. I was being too gentle with the thing and not applying enough constant pressure on the tab and the zipties were a b***h to get a hold of.
37
Oct 17, 2020 11:12 AM
beng37s
Dec 8, 2019 01:21 PM
MrRiv
Sep 29, 2015 04:59 PM
VIVID
Sep 29, 2015 10:58 AM
philttz
Sep 21, 2015 11:12 AM
