About to paint my Calipers !
Old Sep 4, 2011 | 02:18 AM
LegitMW's Avatar
LegitMW
Hey guys I'm about to paint my calipers but I have a few questions. Mine is Sport so I got BBK .
1. I'm planning on painting them myself but what's the average price for professionals to do it ? I'm in SoCal if that helps.
2. Is DupliColor Caliper Spray paint good and durable ?
3. Will I have to sand the Caliper ? If it matters mine is 2011.
Old Sep 4, 2011 | 02:38 AM
Doggy's Avatar
Doggy
Duplicolor is good stuff. The caliper paint or the high heat stuff works good. You need to scuff it up a bit before painting but not too crazy or else the sanding lines will show through the paint. Ive asked around for a shop to paint and I was quoted around 400. But if youre not comfortable painting it yourself then have a shop do it. Not worth messing up your caliper
Old Sep 4, 2011 | 03:24 AM
LegitMW's Avatar
LegitMW
Thanks Doggy. But is sanding really necessary ?
Old Sep 4, 2011 | 04:22 AM
Doggy's Avatar
Doggy
Yes or else the paint had nothing to hold on too
Old Sep 6, 2011 | 09:01 AM
UN1263's Avatar
UN1263
Before you sand, you should use a wax and grease remover to remove dust, dirt and tire silicones. If you don't clean first, you are sanding this garbage into the substrate you are about to paint.
I wouldn't put Duplicolor on a $40K car let alone and $40 lawn chair, but to each his own.
Old Sep 6, 2011 | 09:23 AM
soundmike's Avatar
soundmike
The Duplicolor stuff is pretty good. I've used it a lot over the years, most recently on the Ake's.
Thread on 'Driver.
Old Sep 6, 2011 | 12:40 PM
Doggy's Avatar
Doggy
Duplicolor does make good stuff. You'd be surprised
Old Sep 6, 2011 | 01:38 PM
breftayka's Avatar
breftayka
Those blue calipers would look so sick on a LP/IP/MW and Duplicolor is decent stuff man. I've used it before and had no problem.
For a professional to paint them would be around $150 depending on the color you chose.
Old Sep 6, 2011 | 05:19 PM
SRG's Avatar
SRG
Yeah...like you know anything about modding mr. Scion
Old Sep 6, 2011 | 05:28 PM
breftayka's Avatar
breftayka
LOL.... Isn't it time for you to do your calipers??? It has been months!!!
Old Sep 6, 2011 | 07:39 PM
Z gave way to G's Avatar
Z gave way to G
I can tell you that this gentleman is probably in the collision/automotive painting field. I can tell just by his terminology. That is why he doesn't hold Duplicolor in high regard. I've never personally used it, so I can't argue either way
Old Sep 6, 2011 | 09:34 PM
rAiN's Avatar
rAiN
instead of sanding, use the plastidip
Old Sep 29, 2011 | 07:23 PM
D_Rek's Avatar
D_Rek
I was thinking of doing this to my car too.
Old Sep 29, 2011 | 11:47 PM
cy7878's Avatar
cy7878
The problem with having a pro do it is you will be out of brakes for 1 week.....
I believe most tuner shops will have someone they work with for sandblasting and paint.
There is a shop in Monterey Park called Fast Forward Performance (a Porsche shop) that can sent your calibers out to have them done. The owner Eli has samples in the shop and he can show you the brakes on his own car. May be worth while checking it out.
Old Sep 29, 2011 | 11:51 PM
WPPJR30's Avatar
WPPJR30
Originally Posted by soundmike
I'm diggin' that color...
