Wondering if installing an Injen or R2C intake would be a do it yourself job or better off leaving it to a pro. I am somewhat handy but I've never really worked on cars, other than cosmetically. Thoughts?
Thanks man! I haven't received it yet so not sure on the instructions. I'll take a look at your thread. You da man!
It was a pain in the *** only cause the instructions were terrible and I didn't have all of the parts. I had to make a run to the hardware store so I could mount the second L bracket for the air filter housing.
r2c's will be super easy to install but the injens will be slightly harder because you have to remove the bumper. other then that they are both easy to install
The first thing I did with my G were my cold air intakes. I hadn't worked with the G at all before that, so it really expanded my working knowledge of where things are and how they come together on this car. I fully recommend you do it yourself, just be careful with the MAF sensors when you remove them from the stock tubes and you'll be fine.
