DIY: Grounding kits made simple, step by step guide to making your own!
Old Sep 16, 2013 | 09:36 AM
  #76
FlyLopa's Avatar
FlyLopa
Just did it on my car last night, wonderful improvement with the transmission(7AT), but the only problem is no automatic up windows! How can I fix this?
Old Sep 16, 2013 | 11:18 AM
  #77
Redpit's Avatar
Redpit
1. Push the ignition switch to the ON position.
2. Close the door.
3. Open the window more than halfway by operating the power window switch.
4. Pull the power window switch and hold it to close the window, and then hold the switch more than 3 seconds after the window is
closed completely.
5. Release the power window switch. Operate the window by the automatic function to confirm the initialization is complete.
6. Perform steps 2 through 5 above for other windows.
That was taken from Black Betty's grounding wire DIY.
Old Sep 16, 2013 | 11:41 AM
  #78
FlyLopa's Avatar
FlyLopa
Thanks im going to try it in a bit.
Old Sep 23, 2013 | 12:44 PM
  #79
Batch's Avatar
Batch
2. Close the door.
closed completely.
Just to add to this, you lose the auto-up on the windows any time you disconnect the battery. The calibration in your window gets erased and this process resets it.
Old Sep 24, 2013 | 03:21 PM
  #80
Cheecho's Avatar
Cheecho
I cant get the bolt next to the coolant hose loose is it ok to use any other bolt near by?
Mid project!! Grrr
Old Nov 18, 2013 | 10:34 AM
  #81
dkmesa350z's Avatar
dkmesa350z
Originally Posted by Richardjoseph0
What exactly does this grounding do? Proven?
are you able to read? all of these answers and more are available within this thread and other threads with a quick search
Old Nov 18, 2013 | 10:38 AM
  #82
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
He's got a history of doing this. 90% of his posts are questions about things people have answered hundreds of times, or they're insistence that Injen is the absolute best manufacturer for cold air intakes.
Old Dec 30, 2013 | 10:55 AM
  #83
kmchenry's Avatar
kmchenry
Originally Posted by AZg37
You can pick up the supplies from many different places. Lowes or Home Depot sell wire by the foot, or you can pick up spools of it on ebay for cheap. The terminals can be found at a hardware store, online, or car audio places because they are used for stereo installations.
What and why needs to be oxygenfree? Terminals or wire?
Old Jan 1, 2014 | 09:40 PM
  #84
FYI, I no longer have any of the supplies left. Also I am no longer making or selling grounding wires for quite some time now.
Old Jan 1, 2014 | 10:32 PM
  #85
Darth Kinetic's Avatar
Darth Kinetic
Ok thx for the heads up.
Old Jan 1, 2014 | 10:35 PM
  #86
4rnr's Avatar
4rnr
Those that have had this done awhile ago, has any of the wires start to melt?
Looks like the wires might be a little close to the engine block.
BTW, great write-up
Old Jan 1, 2014 | 10:38 PM
  #87
GoFightNguyen
Because Racecar
Originally Posted by 4rnr
Those that have had this done awhile ago, has any of the wires start to melt? Looks like the wires might be a little close to the engine block. BTW, great write-up
No, it doesn't even get close to being hot enough to melt the wires. I've had them for several months and they're in perfect condition.
Old Jan 1, 2014 | 10:43 PM
  #88
warped ideas's Avatar
warped ideas
A quarter past stripped
I'm a little sceptical, but I'll bite. I'll be doing this tomorrow sometime. I am an audiophile so if this can get the tunes louder I'll try it. It is a little funny now that I'm literally looking at the ground on the battery as I type that the ground only has one smallish wire. My trucks THREE ground wires are ALL twice this size....? It's worth a try for $30-$40.
Old Jan 1, 2014 | 10:46 PM
  #89
GoFightNguyen
Because Racecar
It's a pretty easy DIY, there's instructions on the forum for the lengths you need. I recommend adding some PVC sheathing to protect your hard work.
Old Jan 1, 2014 | 10:48 PM
  #90
warped ideas
Sheathing around what?
