DIY: Cabin Air Filter Replacement Video
Old Jul 19, 2013 | 07:54 AM
  #61
telcoman's Avatar
telcoman
Originally Posted by movinon
I just changed my 2010, with 30,000 miles, cabin filter.
It wasn't that dirty.
I probably could have gone to 50,000 miles.
The majority of my miles are long highway trips, so it didn't take but about a 1/3 of the hours to put the 30,000 miles on then someone who does most of their driving in town.
I used a Purolator, Breath Easy, C25870. It is electrostatically charged and has activated charcoal. The price was $21.99 before taxes at Advanced auto parts, in SW Florida.
It was helpful having a magnetic Phillips head screwdriver.
It would have been more helpful if the screwdriver was at least 10" long.
I removed the 7 screws, the right side plastic cover and the bottom cover.
The glove box pulled loose fairly easily.
When you unsnap the right end of the white cover, in front of the filter, pull the cover to the right to remove it.
The new filter should have a directional arrow that needs to be facing down.
It wasn't obvious to me how the glove compartment should snap back into place.
I knew that the tabs on the right side had to properly line up to the slots, but didn't know what had to align on the left side.
I pushed the glove box back into it's space, but it didn't align that good on the left side, so I tapped it with the palm of my hand, on the left side, and it popped into place.
Tom
I did mine at 15k miles
I only use OEM filters as I had a problem on my old 06 G35 using a purolator filter.
Telcoman
Old Aug 10, 2013 | 11:13 AM
  #62
Vizard_87's Avatar
Vizard_87
Why oh why did I click on this video. I didn't even know about the cabin filter so it's never been replaced in 60k miles. Now I won't be able to stop thinking about all the dirty air I'm breathing in and how black mine must be. Oh well thanks for the video now time to change mine.
Old Aug 12, 2013 | 10:55 AM
  #63
Andres Moya's Avatar
Andres Moya
will this fix the problem with the cooled seats on and off issue???
Old Nov 17, 2014 | 07:00 PM
  #64
sunnyvale2006's Avatar
sunnyvale2006
Originally Posted by Adam West
I don't know if this video has been posted before, but it's a nice visual of how to replace the cabin air filter in the G.
<iframe title="YouTube video player" class="youtube-player" type="text/html" src="http://www.youtube.com/embed/3I5RL0VbYe8" allowfullscreen="" width="480" frameborder="0" height="390"></iframe>
Thanks for sharing. It requires a long-arm screw driver. Where can I buy it?
Old Nov 18, 2014 | 07:39 PM
  #65
hobbs's Avatar
hobbs
Home Depot
Old Nov 18, 2014 | 09:24 PM
  #66
slartibartfast's Avatar
slartibartfast
The dirtier it is, the better it filters. Of course, flow rate drops...
Old May 13, 2015 | 09:56 PM
  #67
ObsidianG37x's Avatar
ObsidianG37x
Thanks OP for the link to the instructional video. Helped make everything go smooth. I had the magnetic philips head already just didn't have that extension. Probably would have been done in 10-15 minutes versus 20-25 minutes trying to squeeze my hand lol and just a heads up, when I was looking for the cabin filter I noticed that the same Fram Fresh Breeze Cabin filter AutoZone and Oreilly's is charged damn near $50 for was only $19 at walmart.
Fram FreshBreeze/Cabin Air Filter CF10743 at AutoZone.com
FRAM Fresh Breeze Cabin Air Filter, CF10743 - Walmart.com
Old Jul 11, 2015 | 01:30 PM
  #68
VIVID's Avatar
VIVID
Pyroclastic Flow
Thanks. You just saved me $100.00. My filter is on the way from discountinfinitiparts.com for a paltry 22 bucks.
Sean
Old Jul 11, 2015 | 08:20 PM
  #69
Roadrash666's Avatar
Roadrash666
If you remove the door from the glove box first, it's much easier to access all the screws. Open the door, disconnect the cable, and pull the door straight toward you. It snaps back on and you reconnect the cable, the whole job took me 15 minutes and I didn't lose any screws.
Old Jul 16, 2015 | 12:12 AM
  #70
VIVID's Avatar
VIVID
Pyroclastic Flow
Started mine tonight.
Everything went back together fine....except I cannot get the left hand screw at the bottom of the door to line up.
I think I really need the long screw driver because when I push up on the bottom of the unit the door shuts slightly and pushes on the screw driver handle off the screw.
I'll have to finish tomorrow because I am getting tired and frustrated.
UPDATE: Done and all set. It did mine at 9K. Glad I did, mine looked like telcoman's. Plus there was a dead winged insect in it...don't know what it was...not an entomologist.
Sean
Old Jul 17, 2015 | 06:29 PM
  #71
TinsleyC's Avatar
TinsleyC
I need to get the longer screwdriver, too. I keep thinking the 12" will work, and I have lost two screws in my two replacements, one each time - the one in the middle falls into the abyss.... You would think I'd learn!
Old Apr 21, 2016 | 06:52 PM
  #72
heftylefty58's Avatar
heftylefty58
Thanks for this tip! Thanks to you, I didn't have to bother buying a longer screwdriver, and I was able to perform this DIY without any issues.
Frankly, I can't believe anyone would attempt to remove their glove box without removing the door first. (I didn't bother disconnecting the door's cable and I was still able to access the 3 screws very easily.)
Just as I was about to upload some pictures showing how easy it is to remove the glove box door, I noticed there's another sticky that already covers this: https://www.myg37.com/forums/d-i-y-i...-box-bulb.html
Thanks again.
Old Apr 21, 2016 | 07:05 PM
  #73
F23jeff's Avatar
F23jeff
nice I have a video to follow, gonna do this next week.
Old Apr 21, 2016 | 07:56 PM
  #74
G37sGraphite's Avatar
G37sGraphite
Did this a couple weeks ago...didn't use a super long screw driver and followed the video. ..no p roblemo!
Old May 25, 2016 | 11:32 PM
  #75
bigc's Avatar
bigc
many thanks for posting this DIY video!
