Need help with spoiler removal
i tried to pop off my chrome spoiler today and i decided to go through it from the interior of the trunk. i couldnt remove this weird plastic screw thing which seemed to flimsy to pull out and fragile to turn. its found holding down the rug-thing to the ceiling of the trunk (bottom of the lid). its not one of those easy pop-off ones.
here are some pics.
does anyone know how to remove them?
also i have the reverse camera, is there anything thing i should know about yanking the wires/ disconnecting them before i actually do it?
here are some pics.
here are some pics.
here are some pics.
I got thru the lining, but can't get the spoiler out... There are (2) easily removable nuts, and then (2) tabs that I cannot get to... anything else?
Anybody had any luck with this removal?
if i remember right, i think there's 4 nuts holding together and the rest should be just molding or double sided tape. try to look and see if there's 2 more nuts. good luck!
^ Yep... upon further investigation and a little head scratching I found all (4) nuts.
(2) in the middle and (2) more on the ends. Then there's white plastic tabs that weren't easily removed, but used a big flathead screwdriver and popped 'em out. Unscrew the back-up cam if you got one and voila!
37
Oct 17, 2020 11:12 AM
