DIY: Smoked/Tinted tail lights w/ reverse cutout
Old Jul 13, 2010 | 06:06 PM
  #106
Nosnibor's Avatar
Nosnibor
Originally Posted by wakeboardr116
After looking at the pics again what pad were you using with the polish?
I used a terry cloth pad for the rubbing and the polishing pad for the polish...lol
  #107
Nosnibor's Avatar
Nosnibor
Originally Posted by Greg Lecewicz
the problem you have is associated with the clear coat you had used. I had the same problem once with my bike. I finished it with a clear specled spray from Duplicolor but I don't remember the brand for sure. I wanted to have some metalic in the final coat and this was avail. This s...t never dried and it was gradually turning dull after several days from applying. I think you have to totally remove what you've put on and start fresh.
Is the stuff hard to get off? I guess I'll find out friday...not gonna listen to the dumb asses at auto zone again.
Old Jul 13, 2010 | 07:58 PM
  #108
hispeed-lowdrag's Avatar
hispeed-lowdrag
this might be why you are having problems. You should be using a random orbital buffer, I used my PC with an orange pad. You could probably get away with a green pad or maybe a white pad
Old Jul 13, 2010 | 08:23 PM
  #109
wakeboardr116's Avatar
wakeboardr116
Yeah I used an orange or maybe even a yellow pad. Then followed up with a white.
Old Jul 13, 2010 | 08:57 PM
  #110
Harley'sG's Avatar
Harley'sG
You're gonna have to use the buffer...don't think elbow grease is going to do the trick.
Old Jul 13, 2010 | 09:02 PM
  #111
Nosnibor's Avatar
Nosnibor
I used a random orbital buffer! He was just asking what pads I applied the product with. I have different pads for different product....but where can I get these pads? Just at the store again? I used the ones that came with my buffer.
Old Jul 13, 2010 | 09:04 PM
  #112
hispeed-lowdrag
oh ok, I thought you meant a terry cloth by hand...but even still a ROB with a terry cloth bonnet won't do the trick. You need to use an orange cutting pad or something close to that. then finish the polish with a white pad
Old Jul 13, 2010 | 11:48 PM
  #113
yogregb's Avatar
yogregb
Just thinking out loud, anybody use this whole technique on the headlights???
Old Jul 14, 2010 | 08:09 AM
  #114
hispeed-lowdrag
I really don't think that would be a good idea. You could very easily end up tinting your headlights to a dangerous level. Not worth the hassle IMHO
Old Jul 14, 2010 | 09:53 PM
  #115
yogregb's Avatar
yogregb
I meant doing it gtr style, like the overlays. The black tint around the edges and side reflector and masking off the headlight/ fog light leaving those areas clear. I plan on doing my tailights this style and think it would be interesting to see if it could be done this way, for guys who don't want to hassle removing and baking the lights...
Old Jul 14, 2010 | 10:22 PM
  #116
hispeed-lowdrag
ooooo ok...I guess you could do it. Personally I think the headlights that have the covers painted/overlay'd look like poo and it really only looks great when the inside is painted, but I suppose you could do it this way. Be the first and give it a try!!
Old Jul 15, 2010 | 12:00 AM
  #117
NiTeHawKPwNeD's Avatar
NiTeHawKPwNeD
BTW.. You don't have to let it dry overnight!
I tinted my friends tail lights off a tundra.. I sanded it with a 800 grit.. Proceeded by 3-4 coats of the spray tint, 5-10 minute wait each interval.
Then proceeded by 3 coats of clear coats within 5-10 minutes..
Let it dry for 20 minutes..
Then started wet sanding it, until the surface is smoothed and sexy.
Use rubbing compound to remove the scratches and etc.
Used paste wax, looks like brand new OEM tail lights smoked.
All can be done in 2 hours!
BTW.. VHT Niteshades is way better than Rust-Oluem Tint..
I am possibly redoing mine tomorrow.. Cuhz mine look POS IMO
Old Jul 15, 2010 | 12:02 AM
  #118
wakeboardr116
Nice. I'd still be careful though. Some paints can take alot longer than others to fully dry and cure. Since you are using a fairly small amount of paint on the lights though it probably doesn't take as long to dry.
How was the light output after 3-4 coats. Seems like that much would be pretty dark.
Old Jul 15, 2010 | 12:39 AM
  #119
NiTeHawKPwNeD
Our San Diego weather today was 84 degrees! It was pretty light actually, I was doing light coats.. It turned out, "light smoked", not dark at all..
I don't usually call them coats.. I just paint them until they are desired by me DOMO
Old Jul 15, 2010 | 12:41 PM
  #120
NiTeHawKPwNeD
Alright I wanted to redo my tail lights.. But I am stuck between with these two screws or what?
What are the secrets removing them?
Here are pictures;
thanks in advance
