DIY: Smoked/Tinted tail lights w/ reverse cutout
Old Jul 10, 2010 | 05:40 PM
  #76
hispeed-lowdrag's Avatar
hispeed-lowdrag
^yes it will go away after you wet sand and then compound/polish it
Old Jul 10, 2010 | 08:16 PM
  #77
Nosnibor's Avatar
Nosnibor
I got the Dupli-Color clear coat cause I figured it would be best to go with the VHT stuff...but the clear coat says that it takes 7 days to cure...is that going to be a problem?? I was planning on finishing up and do the rubbing and polish compounds tomorrow.
Old Jul 10, 2010 | 08:19 PM
  #78
hispeed-lowdrag
No you'll be fine, don't worry
Old Jul 10, 2010 | 08:33 PM
  #79
NiTeHawKPwNeD's Avatar
NiTeHawKPwNeD
you VHT niteshades users are way different from my Rust Oluem tint sprays lol, harder work for me imo!
Old Jul 10, 2010 | 09:37 PM
  #80
Nosnibor's Avatar
Nosnibor
I found this quite easy to do once I got the light out...besides taping off the reverse light...I probably re-did it about 10 times...I'm not satisfied, lol
  #81
Nosnibor's Avatar
Nosnibor
I'll have pics up tomorrow after I get them put back on the car. Can't wait!
Old Jul 11, 2010 | 12:41 AM
  #82
wakeboardr116's Avatar
wakeboardr116
actually paste wax got me somewhere lol
final outcome. thank you for the DIY wakeboardr116!
sexy!
They look great man. Glad I could help.
Ok so this is my first coat....I noticed that I can still see some swirls from when I sanded. That should go away after clear coat, rubbing and finishing right?
Yeah everything should smooth out after you finish the clear coat and wet sand.
Old Jul 11, 2010 | 11:40 AM
  #83
Nosnibor's Avatar
Nosnibor
When I wet sand am I just spraying and sanding at the same time or do I want to wet down the entire area then sand it?
Old Jul 11, 2010 | 11:57 AM
  #84
hispeed-lowdrag
you want the entire area you are sanding wet...I just used a spray bottle with water and a SMALL amount of soap and got the entire area wet. Make sure it stays wet while you are sanding too. It is better to be too wet than too dry (so to speak lol)
Check this out if you have questions...YouTube - Wet Sanding Part 1 of 5
Old Jul 11, 2010 | 01:24 PM
  #85
wakeboardr116
^exactly what he said.
Old Jul 11, 2010 | 02:44 PM
  #86
Nosnibor's Avatar
Nosnibor
Well...I wet sanded, put them back on my car, buffed with a rubbing compound then buffed with a polishing compound and I don't quite have what you have. They are smooth but not shiny. More like a matte than anything...also when I buffed them the paint came completely off on the curves of the lights...
I followed everything exactly on here...
They were shinier at the beginning than they are now...
Old Jul 11, 2010 | 02:56 PM
  #87
NiTeHawKPwNeD
rubbing compound to remove scratches&swirls
follow it up with paste wax
should do the trick, which did mine.
time to put 2 hours
Old Jul 11, 2010 | 03:04 PM
  #88
hispeed-lowdrag
Compounding can take a bit...make sure you are using a Random orbital and using a good compound/polish to get everything smoothed out it is super easy to go back and correct any errors with this mod
Old Jul 11, 2010 | 03:30 PM
  #89
Nosnibor's Avatar
Nosnibor
Mine is a random 6 inch orbital. I'm using M3 rubbing compound and Turtle Wax Polishing compound. After I saw what happened to the edges I was afraid to press any harder...Does this mean I need to start over?
Old Jul 11, 2010 | 03:49 PM
  #90
hispeed-lowdrag
That's really weird that it came off...I used my PC with an orange pad and a fairly aggressive compound and put a good 10-15 lbs of pressure on it...so I doubt it was how hard you were pressing.
I don't know, maybe it wasn't cured or something...did you let it cure overnight before compounding/polishing?
