DIY: Smoked/Tinted tail lights w/ reverse cutout
Old Jul 6, 2010 | 03:15 PM
  #46
wakeboardr116's Avatar
wakeboardr116
Any clear will work probably. I justed used a can of basic clear I had laying in my garage because I forgot to buy some when I got the tint.
Old Jul 6, 2010 | 03:26 PM
  #47
NiTeHawKPwNeD's Avatar
NiTeHawKPwNeD
Originally Posted by hispeed-lowdrag
I used Duplicolor automotive clear coat and it turned out awesome
Thanks you
Originally Posted by Harley'sG
Same here.
Thanks for the 2nd confirm!
I was at Autozone, I picked up rubbing compound.. But forgot to buy clear coat.. so I'm pretty much effed up atm. Waiting for my cousin to arrive here and buy clear coating asap
I have this Roust-Oleum Crystal Clear Enamel, it makes my "test" cups white.. I don't like that.. "for a protective glossy finish" my *** lol
Old Jul 6, 2010 | 04:46 PM
  #48
NiTeHawKPwNeD
I bought rust-oleum that totally messed up my tail lights with the spray tint.. chemical reaction!
so my buddy and I used goo-off to remove the right side light and start over..
I am deciding not to put a clear coat over.. maybe just sand it down, then rubbing compound?, then wax it?
Old Jul 6, 2010 | 04:56 PM
  #49
hispeed-lowdrag's Avatar
hispeed-lowdrag
I would not do that...put a clear coat on. Automotive clear (like Duplicolor) costs MAYBE 6$...it's worth it to make sure there is a sufficient clear coat on there.
Plus if you use a strong compound straight on paint it will jack it up
Old Jul 6, 2010 | 05:16 PM
  #50
Harley'sG's Avatar
Harley'sG
That must be that same crap that I used on my first attempt of this. They turned white! Used paint thinner and started over. Def put a clear coat on them to get the shine, paint alone won't get it done.
Old Jul 7, 2010 | 01:16 AM
  #51
NiTeHawKPwNeD
autozone ran out of dupicolor clear coat.. probably going to try kragen tomorrow, hopefully they have it!
thanks for the help guys!
quick question too;
will "turtle wax rubbing compound" work? after the wet sanding? i was a little sketchy about this red paste looking going on my tail lights..
this is what i have sooo far(i did taping and covering, i did not remove my tail lights). gotta do a lot of retaping tomorrow!
Old Jul 7, 2010 | 09:38 AM
  #52
wakeboardr116
looking pretty good so far. That rubbing compound should work it's not the best stuff though.
Old Jul 7, 2010 | 11:56 AM
  #53
Harley'sG's Avatar
Harley'sG
quick question too;
Turtle Wax rubbing compound works fine, that's what I used. Def better stuff out there but I had it already and gave it a try.
Old Jul 7, 2010 | 12:40 PM
  #54
NiTeHawKPwNeD
Sick thanks for the help guys! Start to do some taping and bagging! Hopefully I will finish these tail lights by tomorrow! excited!
1st coat done.. waiting 30 minutes. it somewhat gave it a glossy look i think
Old Jul 7, 2010 | 02:47 PM
  #55
NiTeHawKPwNeD
Alright So i was going to put the 2nd coat on.. Then wtf happened?!
It looks like air bubble sorta-ish..
Do you think if I let it dry until tomorrow and I can sand it down to give a smooth surface of the tail lights?
or
Let it dry, then apply another coat and hopefully it will even out..
Here are some pictures;
Old Jul 7, 2010 | 10:25 PM
  #56
wakeboardr116
It looks like you may have gotten the first coat a little too heavy. It should still wetsand out once you are done though.
Old Jul 7, 2010 | 10:27 PM
  #57
hispeed-lowdrag
that is EXACTLY what happened to mine!! try wetsanding it tomorrow...I smoothed mine out a bit then I got my PC out and compounded and polished the **** out of it, and it smoothed out just fine
Old Jul 7, 2010 | 11:32 PM
  #58
wakeboardr116
Hispeed how long did you wait between coats? I think that could be part of the problem if you wait to long between then they start to get too dry. I only wait 4-6min between coats of the same paint and about 15 between base and clear.
Old Jul 8, 2010 | 09:42 AM
  #59
hispeed-lowdrag
that actually might be it...I waited ~15 min b/w same coats and 30-35 b/w base/clear
Old Jul 8, 2010 | 10:10 AM
  #60
Harley'sG's Avatar
Harley'sG
I only waited a few minutes between clear coats but was not going very heavy either. Can't remeber exactly how many coats I did but it was several. Getting close man, it's always a learning experience on your first time to do anything.
