DIY: Clean your Throttle Bodies
Old Apr 14, 2012 | 01:43 PM
  #106
Q8y_drifter's Avatar
Q8y_drifter
Originally Posted by ANMVQ
I'm probally I little late to the party on this one ,But why remove the TB. I have always cleaned mine on the car( Usually running ) But was also cable TB cars. I would leave it on the car and clean the intake and runners also. Which I know you talked about being dirty, I was going to look at mine at my next oil change( 5500 miles ) after my SC kit was installed. Sorry for posibly being late.
You leave the engine running while cleaning the TB?
Old May 5, 2012 | 03:09 PM
  #107
abhi89vt's Avatar
abhi89vt
000000000000000000000000000000000000000
Old May 14, 2012 | 02:21 PM
  #108
jjgi5150's Avatar
jjgi5150
Hello All,
Well, here's another satisfied member! Many thanks to the OP for this great how-to post.....I did my TB's today (33K), and they were pretty dirty. I was having the surge/drop at idle issue.
I didn't realize what a difference this small fix could make on drivability. I used to have to worry about a surge/stall at an intersection; now that is no more. It has greatly improved the driveablity...and I actuallly want to drive the car more now....
In fact, that's where I'm headed now...
Thanks again Q8y.....
Take care,
JJ
Old May 22, 2012 | 02:51 PM
  #109
lemonstand's Avatar
lemonstand
Worked like a charm
Cleaned them this weekend as orignal poster described. When coming to a complete stop my car would stutter at around 500-600 RPM. now it idles smooth and never drops below 800 RPM. THanks!!!!!
Old May 27, 2012 | 08:10 PM
  #110
seed3540's Avatar
seed3540
I did this today (28k) and now my idle surges between 800 and 1000. It never used to do that at all. I did notice that I am able to pull off in1st withoutusing
Old May 27, 2012 | 08:12 PM
  #111
seed3540's Avatar
seed3540
I did this today (28k) and now my idle surges between 800 and 1000. It never used to do that at all. I did notice that I am able to pull off in1st without using the accelerator. So the process has been an improvement and a slight setback.
Old May 27, 2012 | 08:40 PM
  #112
Retromoe's Avatar
Retromoe
Take it to the dealership they should be able to fix it for you, just don't mention you interferred with then throttle body. I had the same issue before and the Infiniti tech told me my car was running "too lean".
Old May 27, 2012 | 08:42 PM
  #113
seed3540's Avatar
seed3540
<br />
<br />
I read a bit into this thread and tried the relearning procedure but when I went to try it the problem seemed to sort itself out. :-/
Old Jun 12, 2012 | 07:40 PM
  #114
jjgi5150's Avatar
jjgi5150
Hey all,
Just an update from doing this DIY repair on my G about one month ago....
The difference is just amazing. I was dealing with a lot of difficulty with the surge and 1st gear let-out...made the G VERY difficult to drive smoothly and very prone to stalling...or over-rev when letting the clutch out. It now drives like a dream and was so worth the effort, I can't believe I waited so long to fix it.
I had no other side effect from the repair and as so many others have said...I highly recommend doing this if you have a bouncing/surging idle on your G.
This is an A+++ fix and was very easy to do.....
Thanks again...
JJ
Old Jun 16, 2012 | 04:53 PM
  #115
Alan318's Avatar
Alan318
Throttle Body Cleaner recommendations?
Old Jun 16, 2012 | 05:29 PM
  #116
Rad_Slinger's Avatar
Rad_Slinger
i used seafoam spray.
worked well
Old Jun 16, 2012 | 05:42 PM
  #117
john91's Avatar
john91
Just cleaned mine as usual I never read till the end and removed the harness and hoses and then red that I shouldn't do it.... >.<
Anyway, it didn't change anything. Just put back everything, idle seem much responsive and stops at the right rpm's and doesn't drop lower like it used to do and then almost stall..
The most amazing it goessssss so smoothly into first and second not like before... jerk jerk
Thx for DIY
btw my car has 110k miles and I guess never been cleaned lol. lots of carb
Old Jun 16, 2012 | 06:04 PM
  #118
Q8y_drifter
For me I disconnect the harness but since some ppl had issues with that I figured I'd suggest they wouldn't.
As far as TB cleaner, I recommend CRC TB cleaner. Best I've tried.
Old Jun 16, 2012 | 08:01 PM
  #119
john91's Avatar
john91
You are right, about harness, i just notoice my idle rpms at 1100 all thetime
I've read about relearn procedures, will it help?
Old Jul 4, 2012 | 12:00 PM
  #120
Q8y_drifter
If you do it correctly it should but it takes several attempts to properly do it. Otherwise you can take it to a dealer or any trusty mechanic with a Nissan Consult system and they should be able to do the relearn procedure easily.
