DIY: How to Replace Cabin Filter and Glove Box Bulb
Old Apr 26, 2012 | 04:41 PM
  #91
Meegogrr's Avatar
Meegogrr
Really??? All those step for one tiny light bulb??? I installed all my lights to LED except this one light....sighhh
Old Apr 26, 2012 | 06:05 PM
  #92
If it's too much work for you, ask yourself how often you ever even see that bulb. Only at night with the headlights on when the glove box is open. How often is that in reality?
Old Apr 26, 2012 | 07:59 PM
  #93
Meegogrr's Avatar
Meegogrr
I thot of that as well. But as i was changing out every bulb...theres still that one LED bulb staring back at me like..."por que?". So i decided aww heck...they were all easy to do, i bet the glove box would be the same. I saw that there was this white plastic clip thingi, so i thot if i squeezed the clips the white housing would come out. NO...it didnt...it retracted back in!!! now i cant stand the fact that, that has happened
Old Apr 26, 2012 | 08:11 PM
  #94
Rad_Slinger's Avatar
Rad_Slinger
Ya. You're right, but just having that one lightbulb not be an LED would drive me nuts. The install sucked, but I had the time, so I did it.
Now I don't have to worry about light at night with the headlights on as I try to rummage through my empty glovebox looking for something thats not in there.
Old Jun 26, 2012 | 04:16 PM
  #95
MPdesign's Avatar
MPdesign
The Fram "freshBreeze" cabin air filter says it fits a 2009 G37 but not a 2008?!?
Anyone know why?
Old Jun 29, 2012 | 11:27 PM
  #96
VaTech03's Avatar
VaTech03
I ordered the Fram CF10140 Fresh Breeze Cabin Filter from Amazon for $17 and installed in all of 15 minutes. There were some reports of [perceived] decreased airflow and increased time to cool down, but I didn't notice any difference in mine today in 100+ degree heat--so far so good! The dealership wanted $70 to replace the filter, so write ups like this really help save a few bucks (and you know it's done right with a better quality filter)--thanks!
Old Sep 30, 2012 | 01:44 PM
  #97
Andy77's Avatar
Andy77
Thank you for an informative DIY, which I am planning to do on my new-to-me 2009 G37x. It smells to me like cigarette smoke.
I just ordered the NPN Cabin Air Filter Part #: W0133-1637633 for $14 plus $7 for shipping from autopartswarehouse.com.
I have a couple of questions:
One of the other methods listed in a reply in this thread, 2007-2011 Infiniti G35/G37 Sedan In Cabin Micro Filter Replacement Procedure | Infinitihelp.com , does not mention removing the bottom cover or the right side panel. Can the replacement be done without doing those?
They also want you to remove the harness connector, but you don't. Do you see a problem if I do or don't?
Also, I'd like to clean some ducts if I can. Do you know which are the ducts that feed cabin air into the filter when it is in recirculation mode?
Thanks again for the DIY and thanks in advance to all who help with these questions.
Old Sep 30, 2012 | 09:19 PM
  #98
quakerroatmeal's Avatar
quakerroatmeal
I didn't remove the harness connector as well. There's no reason to unless you plan on yanking the piece around, just be careful. I think you do need to remove the bottom cover though because you grab the entire back cover by the bottom and pull it up like it says.
It was quite easy. The hardest part is probably pulling the damper pin out, I just used a needle nose plier instead since I couldn't get it by finger.
Old Dec 24, 2012 | 11:22 PM
  #99
canoncleguy's Avatar
canoncleguy
Thanks a lot! I am planning to do my 60K service very soon and this is one of the DIYs I am looking for.
Old Feb 18, 2013 | 11:11 PM
  #100
dv_ous's Avatar
dv_ous
Thank you!
Your write up saved me a lot of headache from trying to figure it out myself.
Interesting, I only 3500 miles on my car and the filter is dirtier than I thought for such low miles. I guess Texas air is pretty dirty.
Old Feb 20, 2013 | 12:06 AM
  #101
DanG37's Avatar
DanG37
Has anyone used B72771EA0A? Apparently it's Nissan's grapeseed filter.
2009 Infiniti G37 In Cabin MicroFilter
infinitipartscenter.net seems to confirm it will fit in a G37:
http://infinitipartscenter.net/parts...&siteid=217449
Old Apr 19, 2013 | 06:23 PM
  #102
telcoman's Avatar
telcoman
Thank you Redline.
The G37 seems a tad more difficult than my previous 2006 G35
I just replaced my air filters and cabin filter as I just turned 15k miles. I'm on my second G and found that changing filters every 15 thousand miles is about the right time. I only use Infiniti filters from the dealer's parts department.
Telcoman
Old Apr 22, 2013 | 05:21 PM
  #103
g37flamer's Avatar
g37flamer
thanks has been trying to find a convienet way to change the cabin filter hopes it work
Old Apr 23, 2013 | 05:57 PM
  #104
vince22sh's Avatar
vince22sh
Just change all my bulb to LED except the glove box i guess i gotta buy a filter and get it done at the same time!! thanks guys for the DIY
Old Apr 23, 2013 | 07:12 PM
  #105
Redline37's Avatar
Redline37
Glad you guys found my diy useful!
