Installing SPC rear camber kit
Old Jan 3, 2011 | 12:32 PM
  #31
Originally Posted by Steveo47
Doesn't the kit come with a screw with a flat side to avoid this? Or does that screw serve a different purpose?
The flat sided bolt (it's called an eccentric bolt) is what is required to adjust the toe setting. Elongating the hole it goes through is what gives you a greater range of toe adjustment. If your car's not lowered a lot and you don't need it, great. But proper toe adjustment is as important if not more so than camber adjustment in aligning your car properly so as not to murder tires every couple of months.
Old Feb 28, 2011 | 03:13 AM
  #32
NWG37S's Avatar
NWG37S
Anyone have a SPC rear template they can scan and post up with some measurements? The used kit I purchased were missing the template.
Old Mar 22, 2011 | 01:41 PM
  #33
jjasonSU's Avatar
jjasonSU
^^^Found it here
G35Driver - View Single Post - Toe Bolt Elongation Template Needed
Old Mar 30, 2011 | 10:58 PM
  #34
RaizinCayne's Avatar
RaizinCayne
<iframe title="YouTube video player" width="480" height="390" src="http://www.youtube.com/embed/Av9f6GOAf20" frameborder="0" allowfullscreen></iframe>
<iframe title="YouTube video player" width="480" height="390" src="http://www.youtube.com/embed/eVQPd1aIwIs" frameborder="0" allowfullscreen></iframe>
Old Apr 11, 2011 | 12:12 AM
  #35
huwee06's Avatar
huwee06
Great find!! that should be sticky!! they made it look soo easy ha ha
Old Apr 12, 2011 | 05:46 PM
  #36
advan37's Avatar
advan37
Originally Posted by RaizinCayne
<IFRAME title="YouTube video player" src="http://www.youtube.com/embed/Av9f6GOAf20" frameBorder=0 width=480 height=390 allowfullscreen></IFRAME>
<IFRAME title="YouTube video player" src="http://www.youtube.com/embed/eVQPd1aIwIs" frameBorder=0 width=480 height=390 allowfullscreen></IFRAME>
Thank you man !!
Old Apr 19, 2011 | 10:47 AM
  #37
RaizinCayne
No problem fellas. Should be a great help.
Old Apr 19, 2011 | 11:59 AM
  #38
kRAM's Avatar
kRAM
Anyone know how much adjustment there is with the OEM toe bolts?
Old Apr 20, 2011 | 03:08 AM
  #39
GraphiteG37S's Avatar
GraphiteG37S
I installed my SPC rear camber arms myself and choose to wait on doing the toe bolts until after I got an alignment to see if it's really needed... (keep in mind I have lifetime alignment plan, so it doesn't matter how many times I go back to get it adjusted)... I asked the alignment guy if he thinks that I should bother installing the SPC toe bolts and he said "No, it's not necessary, I was able to get your toe into factory specs."
Old Apr 20, 2011 | 03:17 AM
  #40
kRAM's Avatar
kRAM
Thanks thats exactly what I'm going to do
Old Apr 20, 2011 | 03:20 AM
  #41
GraphiteG37S
No problem, the toe bolts are still sitting in my desk somewhere.. never bothered to use them.
Old Apr 20, 2011 | 08:59 AM
  #42
BooSa37's Avatar
BooSa37
^^I did the same thing, my toe it's dead on, never bother to use them either.
Old May 15, 2011 | 06:25 PM
  #43
EmoPrairieDog's Avatar
EmoPrairieDog
Anyone have offhand what the torque spec for the toe bolt is?
Old May 15, 2011 | 06:33 PM
  #44
EmoPrairieDog
Just found a page in the factory manual pdf... looks like it is 72.5lbs (...at least I assume pounds). Does this sound correct?
Old Jun 8, 2011 | 02:38 AM
  #45
huwee06's Avatar
huwee06
Huh is that right? Guess Ima try this same method but how are they get the toe near spec with oem bolt? How low are you fellas I'm near 2 inch in rear.
