Help How to remove overspray from tint?
Folks, my paint shop didn't do such a good job at masking the car, so i've got overspray inside the cabin.
It's on the dash and other areas, which i'm able to remove with a clay+lube.
However, the tint also has it. I tried clay and liberal lube on a small part, and it's micro-scratches galore.
Any ideas on how to fix this short of getting new tint?
Thanks.
p.s. On a different note, how to remove white overspray on leather?
Thanks.
Not sure if you're still having this problem, or if my solution is relevant but maybe try googone. I tried this and it made taking plasti dip over spray off easily. I know plasti dip isn't permanent so this might not work and I don't know if its safe to use on tints but interior dash should be fine as per isntructions.
37
Oct 17, 2020 11:12 AM
