How do I fix this?
Old Jun 16, 2013 | 09:29 AM
XSman's Avatar
XSman
How do I fix this?
Polished out some scratches yesterday perfectly but over did it on this spot. I went from a heavy, medium, light cut of Menzerna with different pads. Any help is appreciated.
Old Jun 16, 2013 | 11:28 AM
TOGWT's Avatar
TOGWT
Strikethrough clear coat
It should go without saying that you need proper lighting available when you’re polishing. Always work in good lighting conditions, and frequently check your work. Without it you may polish through (breakthrough) paint surface or friction ‘burn’ the paint by polishing in one area for too long.
Basically when friction heat (kinetic force) has compromised the clear coat and exposed the base coat. Paint often looks a slightly lighter colour; it’s usually concentrated on a small area or ‘spot ‘You will also be able to see a non-glossy patch (base coat) where the clear has been removed with the edges of the remaining clear coat being visible .
Areas of risk- bumpers, as they don’t conduct heat like metal panels, edges an seams and the paint in these areas is generally thin (masking tape is good insurance) Applying pressure and holding the polisher stationary for too long will cause friction heat to be concentrated, especially with a foam pad. Clear coat provides both ultra violet (UV) radiation and the paint systems protection. Repair any breaches in the clear coat system otherwise you risk the paint delaminating, which will then require repainting
Correction- replace the missing clear coat and ‘blend to match. Any areas that have been subjected to strike-through need to have another application of base coat sprayed to cover the problem, and then clear coat can be applied to provide UV protection.
The problem is that the new base will tend to lift the edge of the clear around the strike-through spot so you need to seal the gap in the clear coat before you apply more base coat. Seal the spot by using clear coat applied first and allow it to harden sand using finishing paper and then apply more base coat and finally clear coat the entire panel.
It takes some experience to blend the clear coat and a novice painter can cause additional problems until gaining the experience needed to do it properly. Spot blending clear coat is not something an inexperienced painter should attempt.
Old Jul 4, 2013 | 06:48 PM
XSman's Avatar
XSman
Thank you. Lesson learned. All fixed.
Old Jul 5, 2013 | 02:25 PM
lake985's Avatar
lake985
So how'd you fix it? I think I may have 'burned' my paint being to overzealous polishing out a few scratches.
Old Jul 5, 2013 | 04:13 PM
XSman's Avatar
XSman
Local body shop. I'm no painter. Expensive lesson.
Old Jul 5, 2013 | 11:23 PM
SigX's Avatar
SigX
how much did it cost?
Old Jul 6, 2013 | 12:28 AM
JPSBLACKG37's Avatar
JPSBLACKG37
You burned through the clearcoat and basecoat, the quarter panel would have to be repainted to fix... I estimate a $5-$700 fix
Old Jul 6, 2013 | 01:41 PM
SigX's Avatar
SigX
maybe this is a good time to ask how much it costs to get tiny paint ships filled at the dealer? I have probably 10 of them on the front bumper. any ideas? they are all very small, like 3-5 mms, but they drive me insane.
Old Jul 6, 2013 | 06:31 PM
XSman's Avatar
XSman
A little over $400 to paint the quarter panel.
Victory
17
Oct 27, 2022 03:45 PM
delfinparis
Nov 16, 2015 02:26 PM
parkern
Oct 1, 2015 10:15 PM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
Chris_M
Sep 25, 2015 08:38 PM
