Optiseal sealant on glass?
Old Mar 29, 2013 | 05:18 PM
FourT2's Avatar
FourT2
Do you use a sealant on your glass and if so, which one? I use optiseal on my paint but I never used it on glass. Are there any things to watch out for when applying it on glass, like do you have to buff it out with MF after application?
In general, are normal seal paints ok on glass or should I get something like RainX?
thanks
Old Mar 30, 2013 | 06:58 AM
TOGWT's Avatar
TOGWT
Most polymer sealant's will not bond to glass (even Opt-Coat™)
Optimum Opti-Glass™ Coating is an advanced resin coating that forms a semi-permanent film over your windshield and exterior glass.
Old Apr 1, 2013 | 06:17 PM
FourT2's Avatar
FourT2
Thanks. Opti-Glass is expensive, but looks like it lasts for a long time. How does it compare to RainX in terms of durability?
Old Apr 9, 2013 | 06:47 PM
DeepHouseGuy's Avatar
DeepHouseGuy
Bump I'm interested on buying this. Has anyone used this yet?
Old Apr 9, 2013 | 09:51 PM
chris5o4's Avatar
chris5o4
i personally use car wax on my windshield and windows. i like it more than rain-x. give it a try and see if you like it. i usually claybar it first if its my first time applying wax to my windshield/windows. all rain/water starts sliding vertically ~25mph
Old Apr 10, 2013 | 02:35 AM
FourT2's Avatar
FourT2
I tried Opti seal on glass (since that was all I had at the time) and it seems to last about a week. Maybe more, I did not drive in the rain for last few days.
Looks like TOGWT is right, Opti seal it will not bond to glass.
I have this stuff on order, I will give it a try: Glass Science Rain Clear - 5 oz | Free Shipping Available - Detailed Image Looks like RainX.
Old Apr 10, 2013 | 06:39 AM
TOGWT's Avatar
TOGWT
I guess that Ph.D Chemical degree was worth something then
Old Apr 12, 2013 | 06:05 AM
TOGWT's Avatar
TOGWT
Opti-Glass Coating
Durable windshield and glass coating provides unsurpassed protection and water sheeting to provide clear vision
Optimum Opti-Glass Coating forms a durable, cross-linking bond to glass and other silica-based surfaces, providing the utmost in chip, scratch and mar resistance. This coating creates an immense amount of surface tension on glass surfaces that water will simply bead up and roll off at speeds above 35 mph, rendering your windshield wipers virtually unnecessary at highway speeds
Rain, sleet, ice and snow will not stick to treated exterior glass surfaces, providing you with a clearer view of the road ahead. What’s more, Optimum Opti-Glass Coating lasts up to a year and is incredibly easy to apply for maximum protection apply the coating first and maintain the protective coating using the
Opti-Glass Clean & Protect
Directions:
• Apply within a surface temperature is between 60°-90° F (15°-30°C). Do not apply in direct sunlight.
• Thoroughly clean surface and use a product to remove bonded contaminants. Polish glass if scratches are present.
• Before applying, wipe glass down with a 1:15 solution of isopropyl alcohol /distilled water.
• Spray Opti-Glass directly onto foam applicator pad and apply in an overlapping, circular motion.
• Allow Opti-Glass to cure for 2 minutes and remove excess with a clean, dry microfiber towel.
Old Apr 12, 2013 | 10:44 AM
tchoke's Avatar
tchoke
ive used optiseal on windshield and last 2 weeks its been working
the water doesnt fly as fast as when i use rainx but so far so good IMO
G10
Sep 17, 2015 11:42 AM
Detailed Image
Car Care & Detailing
Sep 9, 2015 08:23 AM
Gio37
Aug 19, 2015 01:25 PM
drkashifa
General Tech Questions
Aug 15, 2015 01:27 AM
dAgent
21
Aug 6, 2015 02:15 PM
