Adhesive Removal
Old Aug 6, 2012 | 11:01 AM
nbast's Avatar
nbast
Adhesive Removal
At an autocross this weekend, I used masking tape (all that was available at the event) to tape numbers to my 2009 x coupe.
In the morning is was hot and sunny, then in the afternoon, it rained really hard.
The end result was that the heat melted the adhesive on the tape, then the rain made the paper backing separate, so I'm left with gummy lines on the car where the tape was.
How do you recommend cleaning this off?
I definitely need to get some magnetic numbers...
Old Aug 6, 2012 | 01:21 PM
Rad_Slinger's Avatar
Rad_Slinger
Goo gone
Can be bought at any home depot, autozone, pep boys, advance auto...etc
Works well. Just make sure you a coat of wax on the area you do it on after.
Old Aug 6, 2012 | 08:55 PM
j23a45m's Avatar
j23a45m
Turtle wax - Label and sticker remover
Old Aug 7, 2012 | 08:02 AM
TOGWT's Avatar
TOGWT
Use a 'paint safe' solvent; 3M Citrus Cleaner Adhesive Remover Spray - super powerful cleaner can be used to effectively remove grease, tar and adhesive residue
Old Aug 9, 2012 | 11:15 PM
nbast's Avatar
nbast
Goo Gone worked. I ran it through the car wash after getting the adhesive off.
Definitely not using masking tape to affix numbers again...
Old Aug 9, 2012 | 11:21 PM
G37Vert's Avatar
G37Vert
Correct, next time use Duct Tape.
Old Aug 10, 2012 | 12:05 AM
Weiboy718's Avatar
Weiboy718
^ are you sure about using duct tape?
Old Aug 10, 2012 | 12:30 AM
Rad_Slinger
That's the dumbest thing I've ever heard anyone say.
If he had a problem with regular masking tape, duct tape is going to be 10x worse.
Bad advice is bad.
Old Aug 10, 2012 | 01:09 AM
G37Vert's Avatar
G37Vert
Yes, I'm sure it would be stupid. It was a joke. Didn't think anyone would take that seriously.
Old Aug 10, 2012 | 02:00 AM
quakerroatmeal's Avatar
quakerroatmeal
Did you say you ran it through the car wash? Like a drive through car wash? Those are bad as well!
Old Aug 10, 2012 | 10:20 AM
nbast's Avatar
nbast
Lol, yes. I have not had the time or patience to 'correctly' wash/detail the car. I plan to have it done properly before winter, but I won't be doing it myself...
I also ordered magnetic numbers last night.
Old Aug 10, 2012 | 11:43 PM
G37Vert's Avatar
G37Vert
Good choice on the Magnetic #'s.
Old Aug 21, 2012 | 08:42 PM
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
If anyone would like more info on how to remove stickers, vinyl, etc. check out these two articles:
How Do I Remove the Car Dealership Stickers, Decals, Badges, or Emblems From My Car? – Detailed Image
How To: Vinyl Sticker Removal – Detailed Image
Let me know if you have any other questions and I'll be happy to help.
Greg @ DI
Old Aug 21, 2012 | 10:44 PM
ArmaDen's Avatar
ArmaDen
Yes, Goo Gone works plenty well. Just De-badged the coupe this weekend and it did the trick as it did on the Mada prior to that. Yes, a good coat of wax or paint sealant should be applied afterward as it will strip down to the clear coat. Make sure to use microfiber or a an old cotton t-shirt, hanes or similar, not one that has color or print on it.
37
Oct 17, 2020 11:12 AM
beng37s
Dec 8, 2019 01:21 PM
MrRiv
Sep 29, 2015 04:59 PM
VIVID
Sep 29, 2015 10:58 AM
philttz
Sep 21, 2015 11:12 AM
