Safe to degrease the VQ motor?
Old Mar 29, 2012 | 07:30 PM
Staples's Avatar
Staples
Hey all, the GTM supercharger kit is going on next week and I decided I wanted to degrease the motor to clean the bay up a bit (it needs it). I am petrified of getting water in the engine bay, so I'm taking it to a well known local detailer in the area. Are these motors okay to degrease and spray down? Are there any recommendations to alleviate possible complications? I have detailed the exterior a countless number of times, but never really gave the TLC the engine deserves.
Thanks!
Old Mar 29, 2012 | 07:44 PM
I've done engine bay cleaning a number of times on a number of G's with no adverse effects. When you say "degrease" what are you using? What sort of shape is your engine bay in that it would be greasy?
Old Mar 29, 2012 | 07:55 PM
Staples's Avatar
Staples
When I say grease, I mean; dirt, salt (heavy winters), and grime. It's thick enough that you can't just wipe it off. I figured they would be using some type of chemical to break through the dirt and spray it off. I just wanted to make sure that the MAF sensors and the other harnesses wouldn't be affected negatively once water possibly hits them.
Old Mar 29, 2012 | 08:17 PM
Don't spray the water directly on the MAF intentionally or into the alternator. But splashes won't hurt it. if it makes you feel better, tape some plastic over the MAF connections and put a plastic grocery bag over your alternator. I use this:
P21S Total Auto Wash - 1000 ml Kit | Detailed Image
It works fantastic with minimal or no brushing. If you have tough areas that you need to brush, I use this one:
DI Brushes E-Z Detail Brush - Mini Size | Detailed Image
Old Mar 29, 2012 | 08:20 PM
Staples's Avatar
Staples
Beautiful, I'll be ordering this. Thanks BB.
Old Mar 29, 2012 | 08:21 PM
Post before and after pics.
Old Mar 29, 2012 | 09:25 PM
Redline37's Avatar
Redline37
You should be fine. Just dont flood your engine bay. I wash my engine bay regularly. Anytime it gets dirty, I clean it. Everything seems to be fine. P21S works wonders.
Old Mar 30, 2012 | 04:39 AM
TOGWT's Avatar
TOGWT
Engine Bay Cleaning: Protection of Electrical Components - http://www.autopia.org/forum/blogs/t...omponents-351/
Old Mar 30, 2012 | 08:08 AM
Staples's Avatar
Staples
I just read through, very informative. Thanks for the link.
Old Mar 30, 2012 | 10:46 AM
Staples's Avatar
Staples
Hey Black Betty, will this also remove the oxidation that shows up on the front of the motor (the silver aluminum right behind the radiator overflow reservoir)?
That's one of the worst areas on the motor.
Old Mar 30, 2012 | 11:35 AM
I'm not sure about removing any oxidation.
Old Mar 30, 2012 | 07:39 PM
MACS's Avatar
MACS
As a retired military guy, I sometimes go to the auto hobby shop on base and pay $3 to use the steam cleaner. Works like a charm.
I've used it on a number of cars and trucks and never had an issue with water or steam in the engine bay. Just don't spray cold water on a hot engine, obviously.
I also heard a friend say Honda Brite is good stuff.
Engine cleaning with Hondabrite by S100 - Auto Geek Online Auto Detailing Forum
ajosowiecky
Sep 30, 2015 12:15 PM
misc
Car Care & Detailing
Sep 21, 2015 02:18 PM
