Some advice please
Old Aug 18, 2009 | 06:20 PM
kushBLAZER84's Avatar
kushBLAZER84
Some advice please
Yesterday I washed and detailed my car. Today when I came out to look at it it looked like some insect died or took a crap on top of my hood. I thought no problem since I have a ventureshield installed. So I took some goo gone and then some rubbing alcohol and let it sit there for a minute then wiped it off with a microfiber cloth. After that I hit the spot up with a quick detailer. Only problem is it left a cloudy little smudge mark on where the insect was. Is there anything I can buy at the local auto supply store to fix this problem? It's kind of annoying to look at but I guess I should be thankful that its atleast on the clear bra and not that actual paint of the car.
Old Aug 18, 2009 | 10:45 PM
HamstersG's Avatar
HamstersG
PM "HTP Autoworks" if he does not post up. He seems to be the resident expert on clear bras.
Old Aug 18, 2009 | 11:05 PM
WhiteGhost's Avatar
WhiteGhost
Could the problem have been that you let it sit there instead of wiping it off immediately?
Old Aug 19, 2009 | 02:14 AM
kushBLAZER84
Well I try too all the time but its really not possible to get it off A.S.A.P. every single time. In this case I just got done driving my car, parked it infront of the house, and then when I came out like an hour to an hour and a half later it was already dried up on there. Didn't help also that it was like 93 degrees here.
Old Aug 19, 2009 | 02:21 AM
WhiteGhost's Avatar
WhiteGhost
Sorry, I meant that you left the goo gone and alcohol sit there for a while. However, when initially reading your post I thought you let the goo gone and alcohol sit there for more than a minute. Maybe the combination of the two things, goo gone and alcohol.
Old Aug 19, 2009 | 02:45 AM
CEELOSG37S's Avatar
CEELOSG37S
LA G Club
Dude goo gone aligned perfectly on all the sentences. hahaha.
Old Aug 19, 2009 | 01:54 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
I think it might have been the combination of the goo gone and alcohol. I've only ever used goo gone and never had a problem. Then again I don't have a clear bra so it might be something in the material of the clear bra.
Old Aug 19, 2009 | 07:08 PM
Pat's Avatar
Pat
It's best to start with least aggresive methods first, next time try some quick detailer. As for the stain, is it where your goo gone and alcohol solution was or is it only where the insect was? If it's just where the insect is then it's probably an etching from the bug guts. My suggestion would be a gentle polish with a black pad at a slow speed. If you don't have any machine polisher, try scratch-x by hand.
Old Aug 19, 2009 | 07:20 PM
kushBLAZER84
Ya it was only where the bug was. And I'm pretty sure that the goo gone and alcohol didn't cause it, it's about the size of a dime, maybe little bit smaller.
delfinparis
Oct 8, 2015 06:06 PM
G37sPhoton
Oct 4, 2015 11:08 PM
arkyv714
Oct 4, 2015 03:44 PM
ajosowiecky
Sep 30, 2015 12:15 PM
BurtoN86
Sep 30, 2015 03:32 AM
