Clay Bar Help!
Old Jul 25, 2009 | 05:45 PM
07BlackG35Stud's Avatar
07BlackG35Stud
Clay Bar Help!
Hello all,
So, my car's paint is in very good shape. Even though it's a black car, and it does have some fine micro-scratches, I would say the condition overall is excellent.
This morning, while detailing my car, I noticed a few dots on certain areas of my car's clear coat that contain tiny, dots of rust - they are VERY VERY tiny, I would say less than a millimeter in diameter. I live very near a railroad track, and I'm pretty sure these are metal shavings that come off during a clay bar process.
I just went on DetailedImage.com and noticed there are many types of clay bars and lubricating sprays, and I would like to know what's recommended for a car with paint that's in great shape. I'm not sure I want to use the medium grade because apparently it can be rough on the surface of the car, but then I'm not sure if the fine grade is what I need?!?
What do people in my situation use? Has anyone experienced the whole "rusty metal shavings" on the clear coat?
Any advice would be greatly appreciated. Also, I should go ahead and wax my car right after a clay bar session correct?
Thanks!
Old Jul 25, 2009 | 06:13 PM
I have BO and detail a lot. I wouldn't get medium grade clay unless your paint is in poor condition which by your description and the photos in your other post it doesn't seem to be. I personally have used the Clear Kote fine grade clay bar. I originally used the Clear Kote Quik Shine clay bar lube, but once it was used up I switched to other products I liked better.
I prefer PBW Pray & Gloss or CG Luber.
A word of advice about clay on our BO paint: Be very careful and use plenty of lube and the minimum pressure necessary. It will cause fine scratching in your finish. Yo may need a finishing polish afterward in my experience, so use the clay before you polish and not after. Rub the surface with your hand covered in plastic wrap before and after doing a section in order to feel the difference. You may not see much difference visually, but you will definitely feel it.
I recommend washing your car again after claying before a wax to make sure you've completely cleaned any residue that may be left after the clay.
Old Jul 25, 2009 | 06:36 PM
07BlackG35Stud
Thanks man! I will jump on this next weekend. So, the rusty dots should be able to come off with the clay bar, correct? I just want to make sure it's not too late, and I hope not! Also, I should stay away from the clear bra correct? I know clear bra's can be waxed but not sure about clay barring them...
Old Jul 25, 2009 | 08:10 PM
Dan1's Avatar
Dan1
Just go pick up some Mothers yellow clay. Its comparable to Sonus green which is also a very light clay.
Old Jul 26, 2009 | 06:13 PM
gicode0823's Avatar
gicode0823
I just finished the detail and I used Dodo-Juice Born-Slippy Clay Bar Lube for the lube.
4DRZ
May 29, 2024 09:28 AM
djdiskino
Sep 29, 2015 07:18 PM
GFTW
Sep 19, 2015 03:52 PM
