Wow, I have the worst luck...George or anyone else help!
Old Feb 22, 2008 | 07:28 PM
RedlineSi's Avatar
RedlineSi
*UPDATED PICS*Wow, I have the worst luck...George or anyone else help!
Well, you guys already know about my swirl hell from the dealership, and today I found this bad boy. I took these pics after using a touch of scratchX by hand...which obviously does very little.
I am not sure about if it was keyed, scratched by accident, or caused from the dealership. I talked to the service manager today and he said he would have one of their detail guys buff out my car...which I obviously don't want. I was trying to explain to him over the phone I didn't think this scratch would come out...but maybe it can. Either way I want to do it my self. Before I do that, do you guys think I should try to have my service manger let someone from the Body Shop look at it, and not some kid? Take a look guys. George, do you think I could use the PC I ordered to get this out? Will PO106FF work? Will I need a different pad then white? Maybe an Orange...or Yellow?
*UPDATED PICS*
Old Feb 22, 2008 | 07:32 PM
Blackjack's Avatar
Blackjack
Doesn't look bad at all... Pick up some ScratchX from Autozone, Pepboys, or I think even Walmart has it and it should come right out.
Old Feb 22, 2008 | 07:36 PM
solopresident's Avatar
solopresident
looks like it polishable.
Old Feb 22, 2008 | 07:43 PM
RedlineSi's Avatar
RedlineSi
I have scratchx, but I used it by hand. My Porter Cable from George arrives Monday. I can feel it with my nail, but it doesn't go to the paint, but it definitely went into the coat.
Old Feb 22, 2008 | 08:31 PM
Callaway's Avatar
Callaway
Arm flailing tube man
that will buff out no problem.
Old Feb 22, 2008 | 08:44 PM
infidsg35's Avatar
infidsg35
You may need to start with a polish that is a little more abrasive then end with a ultra fine polish..
Old Feb 22, 2008 | 08:48 PM
solopresident
how did u do it?
Old Feb 22, 2008 | 11:43 PM
Jkg37's Avatar
Jkg37
i had smiliar scratch... compound will not going to fix the proble... i paid 40 went to dealer and wetsand my car... problem solved
Old Feb 22, 2008 | 11:57 PM
vinnys coupe's Avatar
vinnys coupe
dammm yeah it should buff outt
Old Feb 25, 2008 | 01:55 PM
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
You may need a more aggressive polish than the PO106FF to get the job done, but it looks pretty faint. At a minimum, you'll be able to minimize it to the point where it won't bother you. If you need a more aggressive polish, something like Intensive Polish or Power Gloss would work well with an orange or yellow pad, then follow up w/ the PO106FF. With the PC, since it's a safe machine, you may need multiple applications of the compound to get the results you're looking for. Take your time and apply some good pressure and you'll be pretty pleased with the results. Be sure to end w/ the PO106FF for maximum depth and gloss.
If the compound doesn't do the trick, you can try a light wet sand.
Keep us posted on how things turn out for you.
George
Old Feb 25, 2008 | 02:35 PM
RedlineSi's Avatar
RedlineSi
George
Well, I can't believe it. I found more damage today on the same damn side panel that went to the metal. Looks like someone in the work parking lot dropped something on it, something hard. I am just getting the whole panel repainted. Sucks....
George, you got any advice for me dealing with a freshly painted panel? I am guessing I should give it a good 90 day's to cure before I seal and wax it? I still need to take care of the rest of my car, as far as the swirls, will it be stupid to clay, polish, glaze, seal, and wax the rest leaving out the fresh panel?
Old Feb 25, 2008 | 03:32 PM
LAZY TURBO's Avatar
LAZY TURBO
polish should get that out, its nothing to severe.
Old Mar 1, 2008 | 10:11 PM
johng35m's Avatar
johng35m
scratchx will fill in that scratch temporarily. scratchx does not trully remove the scratch. it has fillers that "fill" the scratch in. overtime, it will appear again. your best bet is to use a compound via buffer then follow it by a polish, then seal/wax it.
Old Mar 2, 2008 | 10:10 AM
Detailed Image
I would say give your freshly painted area at least 90 days to properly cure. You can still wash, clay, polish and glaze the fresh paint, just skip applying a sealant or wax. Polishing your entire vehicle should give it more of a uniform look with the fresh paint. Time (the 90 days) will go by faster than you think.
George
G37sPhoton
Oct 4, 2015 11:08 PM
Morgan Thompson
Sep 5, 2015 01:24 PM
Mattlorentzoe
Aug 21, 2015 05:09 PM
abretz89
Aug 20, 2015 11:58 PM
