Project Panda
Old Apr 4, 2019 | 04:32 PM
  #61
qmantran's Avatar
qmantran
Nice rpf1s you got there. What size are they?
Old Apr 4, 2019 | 04:34 PM
  #62
projectpanda13's Avatar
projectpanda13
Thanks, sadly they are 17x9 and won't fit on the G. I had them on my previous car. I'm trying to sell them now.
Old Apr 5, 2019 | 03:46 PM
  #63
qmantran's Avatar
qmantran
I have 18x9 +35 rpf1 in the rear. They clear the rear akebonos but not the fronts.
Enkei told me the fronts will need 18x8.5 +30 to clear front akebonos.
Old Apr 5, 2019 | 03:52 PM
  #64
projectpanda13
Dam that looks so good. I know 18x9.5 +15 also clears the Akebono up front, but +38 will not.
Old Apr 5, 2019 | 11:11 PM
  #65
qmantran's Avatar
qmantran
I wouldn't recommend 18x9.5 +15. Those are really aggressive and will protrude pretty far past the fender.
There's a guy I'm following on Instagram with 18x9.5 +15 rpf1 in SBC on his g37 6 speed with akebonos and they look really aggressive.
This is how my 18x9 +35 look
Even my 18x9 +35 sticks out a bit more than I would like. The 18x9.5 +15 stick out WAY more.
Old Apr 5, 2019 | 11:26 PM
  #66
projectpanda13
i agree it’s aggressive on a sedan but if someone really wanted to, with enough camber it can fit. I’d like to get something lighter than what I currently have and don’t want to rock RPF1s again, but they are so hard to beat for the price and weight
Old Apr 6, 2019 | 09:50 AM
  #67
qmantran's Avatar
qmantran
Enkei nt03+m are cheap and light.
Old Apr 10, 2019 | 10:36 AM
  #68
projectpanda13
I was very disappointed over this past weekend. I was expecting the subframe collars to be at most a 1 hour job but it ended up taking me 4 hours.
First, the captive-weld nut in the chassis that the small sub-frame brace is held in by breaks on me so I had to cut the bolt off. I spent most of my time trying to find something that would fit in the space and I didn't have anything to burn it off.
I also sheared off all three bolts that held up the plastic rear shield.
During the process of installing the collars, I guess my rubber bushings were in such great condition that I had the hardest time fitting it in. I had to resort to using a jack with a tube pipe to push the collar in.
This is how it current fits in the rear. Is this normal?
I sold this particular lip a while back and bought one brand new pre-painted, but I never installed it since my bumper was in such bad shape. This lip happen to be on sale by the guy I sold it to and asked if I could buy it back. Now, I have a crappy lip with a crappy bumper. A perfect match.
Old Apr 10, 2019 | 10:50 AM
  #69
Baadnewsburr's Avatar
Baadnewsburr
sucks to hear...almost sounds like you are working on a northern car...broken bolts seized from corrosion is usually half the working time in areas where they use road salt....tons of PB blaster and a good thread chaser set is a must up here ... I hope you post a you tube video on your install though...Iv'e had my collars sittign i nthe garage for at least a year now waiting on me getting to them...
can you post better pics of the bushing sitting? its hard to tell from the pic posted but it does look to be sitting a little high
Old Apr 10, 2019 | 10:55 AM
  #70
projectpanda13
I did some recording and I'll edit the video tonight or tomorrow and post it up. I'll swing by by car tonight and get some photos for ya.
Old Apr 11, 2019 | 04:08 PM
  #71
qmantran's Avatar
qmantran
I also just installed Z1 subframe collar inserts yesterday. The top collar inserts were simple and easily fell into place. The lower collars were a bitch. I sprayed the bushing with silicone lubricant and also sprayed the collar inserts. Didn't make going in any easier. I had a rubber mallet to beat it in and didn't have any luck. Since I had the car up on a lift I decided to grab a pole jack and use a 38mm axle nut socket to help press the lower inserts in. Everything went in fine after that.
Took me about 1.5 hours and that was because I wasted a good bit of time trying to use a rubber mallet to hit the lower collar in. I finally decided to just remove part of my exhaust to get more access and use a pole jack to press it in.
Old Apr 11, 2019 | 04:31 PM
  #72
projectpanda13
Question: Does the rear top collar protrude above the rubber bushing a bit, unlike the front collar? I thought it odd that the front collar sat flush with the rubber bushing and my top rears did not.
I had a lot of trouble with my rear bottom collar. I had to use jack and tube to get enough force to push it in.
Old Apr 11, 2019 | 07:15 PM
  #73
qmantran's Avatar
qmantran
Old Apr 12, 2019 | 08:55 AM
  #74
projectpanda13
Thanks for the reference pictures. Mine looks the same then and I have nothing to worry about.
Hopefully I'll have my diff bushing cut out and replaced this weekend. Once I have that done, I should be smooth sailing for the rest of the install of the differential and my exhaust.
Old Apr 12, 2019 | 09:53 PM
  #75
jpowersjr2's Avatar
jpowersjr2
I used my jack to push the subframe up and then began bolting it back. It eventually went into place properly.
