ZahyMatar's '13 KAD G37S 6MT Sedan Build
Old Apr 13, 2017 | 01:29 PM
  #76
That's a great idea. At what point do I need to purchase extended studs? Over 3mm?
The info I've got stuck in my head is that you can use standard length studs when 5mm or less, just like Brad said here. More than that, and you compromise the thread count, and need to use extended length studs.
In so far as minimum width on spacer adapters, I think that's 15mm.
Could run a 275/35 rear with camber in the -2 range.
Z puts a lot of miles on his cars. I suspect he wants a more normal camber.
Old Apr 13, 2017 | 01:38 PM
  #77
ZahyMatar's Avatar
ZahyMatar
I actually get out of the military this summer, right before the annual meet this year. So no more trips between NC and NJ. My annual mileage will be going down quite a bit. And now that I no longer have an AWD G, I'll be looking into purchasing either an older Toyota Tacoma, 4Runner or a Subaru Forester as a daily/winter car.
Old Apr 13, 2017 | 03:24 PM
  #78
Zahy, too bad you don't have a coupe regarding those Volks, perfect offsets then. I've got the feeling you're not going to dig the poked fitment since you're really wanting those (4) front Nismos. I'd still continue pursuing those or talk w/ Ravspec, I still think the SSRs would be a go without spacers based on that other member running quite a bit more conservative specs w/ his BBK. And I'll dig around too.
Here's some new gunmetal front Nismos new~
https://conceptzperformance.com/niss...6a_p_13367.php
And a cheaper link (I've ordered a few Infiniti parts from them)
http://www.quirkparts.com/nissan/370...-and-trim-scat
And the deal of all deals at $279.24 per (have not dealt with them though)
http://www.oemautopartsandaccessorie...ed7b278965c8f/
Old Apr 13, 2017 | 10:13 PM
  #79
ZahyMatar's Avatar
ZahyMatar
Wheel, Alloy for 2014 Nissan 370Z|D0C00-1A36A : Quirk Auto Parts | OEM & Aftermarket Car, Truck, SUV, & Van Parts and Accessories
Wheel, alloy, 19" w/Nismo, front for 2014 Nissan 370Z D0C001A36A Securely check out today - it's quick and easy.
Really appreciate the help, Brad. Quirkparts seems like a pretty good deal.
These are the NISMO wheels I am after:
I also tried calling RavSpec like 4 times today, and even leaving a voicemail. No response. Kinda bummed out, I'll try again tomorrow.
Old Apr 13, 2017 | 10:16 PM
  #80
Coltrane1's Avatar
Coltrane1
Nice find on that last link Brad! I've been searching for 4 fronts in that Nismo wheel too. Unfortunately when I load 4 fronts of the 2012 style 370Z wheel, front or rear actually, the only thing that gets added to their cart is "style #3." I'm wondering if they're out of stock on Nismo wheels and the cart is only filling whatever wheels they have in stock...worth a phone call.
I think the part number for the '09 Nismo wheel is D03001A36B?
Edit- I persisted with the cart at the last link and at checkout it says "out of stock." I wonder if anyone who lists these wheels for sale actually has them.
Old Apr 13, 2017 | 10:51 PM
  #81
ZahyMatar's Avatar
ZahyMatar
I think the part number for the '09 Nismo wheel is D03001A34B?
Just noticed you have Stance XR1 coils, how do you like them?
Old Apr 13, 2017 | 11:03 PM
  #82
Coltrane1's Avatar
Coltrane1
They actually arrived today. They'll be installed next week - I'm curious to find out too
https://www.myg37.com/forums/brakes-...awd-g37xs.html
Old Apr 14, 2017 | 12:21 AM
  #83
Coltrane, the part # on those Front 2013 Nismos in gunmetal is D0C001A36A
Old Apr 14, 2017 | 01:56 AM
  #84
Goonz's Avatar
Goonz
Are you planning on using spacers with those wheels? If so then I'd make sure they have the appropriate groves as my some what 370Z wheels didn't.
Also Quirk parts is not that far from where I live. I tend to get my small accessories such as valve stems and NISMO stuff from them.
Also, how about this wheel?
Old Apr 14, 2017 | 08:46 AM
  #85
ZahyMatar's Avatar
ZahyMatar
Those are nice, but relatively common the G's. Whereas I've only ever seen one sedan on the 2015+ NISMOs.
Old Apr 14, 2017 | 09:17 AM
  #86
Are these the wheels you're talking about? Heck, yes!
Old Apr 14, 2017 | 09:47 AM
  #87
ZahyMatar's Avatar
ZahyMatar
Nope, referring to these, which are also made by Rays, Forged, and the fronts only weigh 21lbs.
Old Apr 14, 2017 | 10:53 AM
  #88
Dembflyr's Avatar
Dembflyr
The 15's were on my list as well. They would look great on your G and they'd be unique.
Old Apr 14, 2017 | 01:12 PM
  #89
Goonz's Avatar
Goonz
Oh, then D0C001A36A may not be the correct part number then. I see the wheels you want on ebay all the time as well as the 370Z forums. Everything is in CA for whatever reason, damn you guys and your warm climate.
Old Apr 14, 2017 | 04:30 PM
  #90
ZahyMatar's Avatar
ZahyMatar
Got my emblemless grille installed! If any of you guys want something done just like this, contact David Fraide, Dfraide@gmail.com
$250 for all black, or $350 for 2-tone, shipped back to you.
​​​​​​He's located in Texas, I'm very satisfied with his work. The grille looks great.
