What tires are you running, I'm sure it's in this awesome thread somewhere but glossed over it I suppose. And what tires are you planning to replace them with?
The wheels came with Barum Bavaruis 3 tires. They are an off brand made by Continental.
All the reviews I have read have good things to say. These are super cheap for a performance 19" tire at about $150 each. After driving on them for a few thousand miles I have to say they are not bad at all. I drive about 15,000 miles a year so I will sacrifice some performance to get a little more longevity out of the tires.
The dry performance is very good. Not RE-11 good by any means but I haven't felt limited by the tires until I installed the sways.
I haven't given a lot of thought about what to replace them with as I am still recovering from the purchase of the Nismo wheels and my winter tires.
If I were making the decision tomorrow I would have to seriously consider the Barum tires again.
Yeah, when you said your tires were the limiting factor I assumed you weren't happy w/ them, glad to hear they're holding up.
Awesome build and thanks everyone for the reviews of Anti-Roll Bars.
I noticed that some of you are realizing that tires are now the limiting factor after installing ARBs and just wanted to share that overly stiff ARBs will lower ultimate available grip as the lessened weight transfer now scrubs the outer tire at a more shallow angle.
I have the ARBs off of a Nismo 370Z waiting to go on. I've found that they are the same outer diameter as the S sedan but thicker walled. It also matches the diameter and wall thickness of the ones Nismo made for the V36 sedan
Anxious to see what the Nismo tune for this chassis holds.
I think that my current tires do not have a very stiff sidewall. I feel like they are folding over a bit. That's why I say they are limiting. However for a street car that will probably never see a track they add that extra feel when entering a corner at speed that make the driving experience better.
I was on the fence about sways but now I'm sold. These should've been at the top of my list.
I am curious to see what your thoughts are on the nismo sways.
I'm glad it didn't destroy the integrity of the bumper itself...just some paint work for the most part. Maybe you will make out for under 500 and not have to inform insurance
Well, I found a little extra money for one more mod that I've been wanting.
I picked up a Torque Solution short throw shifter for $120 off eBay. I then paired it with a Raceseng Sphereology weighted ****. This **** has a poly screw on cover so it's more daily driver friendly. I think it fits the interior perfectly. No getting around the $165 for that.
I will be addressing the trim ring as it has a few small dents and I'd like to get rid of the shift pattern. The **** has the shift pattern on it so it's not needed on the trim.
I absolutely love the feel with this shifter and ****. It's exactly what I was hoping for.
Unfortunately I have some buzzing from the vibrations. I understand that it's fairly common with an STS. I'll have to see what, if anything, I can do.
