G37x awd - TT kit
Old Dec 9, 2015 | 11:59 AM
  #31
warpeacelove's Avatar
warpeacelove
Here is LEGEND one PIC ONLY.
Old Dec 9, 2015 | 12:05 PM
  #32
ttv36's Avatar
ttv36
Race, repair, repeat.
^ Thanks for the updates, but I'm confused! You went from installing the TT kit to just mildly throwing a built block in? Crazy!
Care to share details on the block?
Old Dec 9, 2015 | 12:20 PM
  #33
warpeacelove
This Stage 1 VQ37 Long Block is good for someone who wants a safe naturally aspirated, turbo charged, or super charged Nissan 370z or Infiniti G37. The stage 1 package is good for up to 650-700 Rwhp(with added L19 Head studs).
This Package includes:
Wiseco or JE Pistons .020 over
Eagle H Beam Rods
ARP Rod Bolts
Block inspected and cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Rotating assembly balanced
Crank magnafluxed and the journals micro-polished
New Moly coated Race Spec main bearings installed
New Moly coated Nissan OEM rod bearings installed
Block prepped and assembled
New OEM Head Gaskets
Heads inspected and cleaned
Heads redecked
Ported exhaust and intake runners
3 angle valve job
New OEM Valve stem seals installed
Valve Stem Heights set
Cold Clearance set for stock cams
Heads prepped and assembled
New OEM Oil Pump
Engine will come with Heads bolted to block and torqued to spec
ARP Main Studs
WISK643M96 Wiseco K643M96 96mm/9.0:1 Compression Pistons -
L19 Head Studs
Old Dec 9, 2015 | 01:16 PM
  #34
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
Good updates! Hope all is well, what's the word on completion dates?
Old Dec 9, 2015 | 01:25 PM
  #35
ANMVQ's Avatar
ANMVQ
Eagle H Beam Rods
ARP Rod Bolts
Block redecked
Heads redecked
3 angle valve job
New OEM Oil Pump
ARP Main Studs
L19 Head Studs
AH Importpartspro block !!
I've been looking at that also.
BTW nice color car. Same as me
Old Dec 9, 2015 | 02:14 PM
  #36
ttv36's Avatar
ttv36
Trying to see if he'll be done before you or what?
Old Dec 9, 2015 | 02:22 PM
  #37
warpeacelove
LMAO. I will be done hopefully at the end of the Week no later than Wednesday of next week.
Old Dec 9, 2015 | 05:30 PM
  #38
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
I'm just going to drop off it off and forget I even own it for a while.
Nice! Hope all goes well!
Old Dec 13, 2015 | 10:53 AM
  #39
Waste86's Avatar
Waste86
Nice! How do you like the IPP block?
Old Dec 13, 2015 | 12:59 PM
  #40
That's one sweet shopping list of motor parts, really looking forward to your finished project, built for the long haul.
Old Dec 16, 2015 | 08:58 AM
  #41
PongSanity's Avatar
PongSanity
Noticed that you selling your boost controller. What would be your replacement?
Old Mar 6, 2016 | 11:44 PM
  #42
Slateg37's Avatar
Slateg37
Amazing build..
Old Apr 4, 2016 | 10:10 AM
  #43
warpeacelove
ECUTEK will be my Boost controller.
Old Apr 4, 2016 | 10:40 AM
  #44
PongSanity's Avatar
PongSanity
They got the bugs worked out to support it? The last time I spoke to seb, they were still trying to make it work. If this is the case, and ecutek can monitor/control boost, I'll put my innovate boost controller up for sale bnib.
Dman25
Oct 15, 2015 11:57 AM
DiegoMontoya
Sep 22, 2015 11:05 PM
ArmyBoyd
Sep 22, 2015 08:54 AM
jfisher
Sep 13, 2015 07:58 AM
EnYcee-G
Sep 3, 2015 04:35 PM
