The "4 door Z" build (4DRZ)- 13 G37S 6spd sedan
Yet this guy here is asking $12,000 for what looks like a clean, stock 2013 6MT Sedan.
https://www.myg37.com/forums/g-s-fs/...6mt-sedan.html
I genuinely have no idea what my car is worth. I guess around $15k... certainly less than that on trade (if at all, because mods), or more for the right buyer buying the right car. But probably not much more.
No way is a G37S realistically selling for 30+.
And every year it gets another year older, LOL.
Well, I'm keeping it at least two more years, if not longer. Probably longer. Not to ***** the OP's thread, but he started talking about resale value, so it's all good I suppose. My only significant concern is worrying about gasket failure in the rear timing chain cover. Other than that, I'm still very content.
No, that's not true. I also worry about minor damage that actually totals the car. I'd be lying if I said that didn't bother me.
True but it sounds like your clean car will only fit the 'right buyer'. I've never had an issue selling any of my cars either because they are cleaner and better taken care of then 99% of the comparables.
I was doing some research a few weeks ago and Carmax had a 2013 6MT w/44k miles for 20,900 which sold almost instantaneously. There's a buyer out there for everything.
What a great thread! I have loads of questions, for the mods I'll be doing this spring. I'll create posts for those.
The real reason for the reply: How are you connecting up the resistors to cancel the airbag light? The values for the resistors shouldn't change. The only thing that could is if corrosion is building in the connection to the resistor and causing the total value to drift, triggering the airbag light and when you change to a new one, everything is clean again. Just a thought.
All the resistors only last about 4-6 months before throwing an airbag light. They have never had any sort of corrosion. The issue is that no one has really tried this on a 2013 so I am left to guess the correct resistance without taking the risk of hooking up a meter to my stock seats and triggering the side air bag. I am running the same type of resistor that Bride makes specifically for Nissan now so hopefully this will be the end of all this BS.
Non definitely DO NOT hook up an ohm meter to the airbag! I was thinking the leads were getting a thin oxide coating. There's no way they are drifting out of range. Maybe try increasing the resistance by a little?
Rochester, in my 11 year old car, I'm sure EVERY bushing is rotten. I looked at those collars, seems like a very easy way to "create" a semi metallic bushing. Saves a ton of labor over replacing them. Since the bushings are not serviceable, according to Nissan, I'm guessing they're not available? IIRC, there are poly urethane aftermarket bushings out there. I HATE poly squeaking, though the subframe probably won't.
And honestly I'm just laughing at myself, because it's a safe bet I'll slip those collars in some day, looking for something to do.
Fire away when you have any questions. I am running out of mods to do for this car. But that also means this car is becoming pretty sweet.
A thought - you might need a milspec resistor. Milspec usually means a wider heat range without substantial change in resistance; that is often a problem with cheaper car electronics - the components can't handle the heat range of a car interior or engine bay.
