Jonesmeister's Build
Old Apr 21, 2016 | 09:36 AM
  #136
Kris9884's Avatar
Kris9884
Originally Posted by Jonesmeister11
I was disappointed to find out the car had stability control you cannot turn off, bummmer dude. I didn't want to pull a fuse or anything like that so I followed Lt*Che's thread and it works awesome!
Ok so I finished the install about 4 hours ago. Lt8Che's pic was correct! ONLY thing that differed was the location of the Bosch box. On a 6 speed, the box is behind the shifter. Wiring is the same and uses the same pins.
Attached are my pics. Please don't judge how dirty it is, I need to clean it up and I forgot to reinstall the composite plugs, so I will be removing the center console one more time.
Oh and it does work! On is on and off is off!
Killer build man, love the video of the runs on the strip. Is this considered the "brake light mod"? Aka you can do a burnout or drift etc without the slip and traction kicking in?
Old Apr 22, 2016 | 12:34 AM
  #137
Jonesmeister11's Avatar
Jonesmeister11
Appreciate it! I'm not sure about the brake light mod, I think that's pulling a fuse? Well with the yaw sensor temporarily disabled, I can certainly drift, but I'm not sure about a standing burn out or dounut. I haven't tried yet, one because I don't know how to lol and two I dont want any attention from law enforcement lol.
May 15, I'm going to a drift event and will try a few passes. Not expecting to be good, but I'll have fun. Partially because I've never done a drift at a high speed nor have I felt comfortable trying it in a parking lot. Last thing I want to do is wrap my car around a light pole :/.
Anyway I'll post back once the event is over!
Old May 18, 2016 | 09:01 AM
  #138
Jonesmeister11
So i copied Rochester and recycled the factory shift boot. Going to see if i can get my girlfriend to fold the "leather" and put a stich on it so it looks better. Until then i used black shoe polish to dye the fabric black.
Attached Thumbnails Jonesmeister's Build-1463574979226.jpg   Jonesmeister's Build-1463574998595.jpg
Old May 18, 2016 | 09:08 AM
  #139
The OEM boot has four 1" leather tabs intended to wrap over the inner ring and zip-tie. You know what I'm talking about, and from your pics it looks like you lopped them off.
Instead, I inverted the boot, and slipped it on (with WD40, because tight ft) inside-out, pulling it down the handle with those tabs. Then you re-invert the boot over the arm, and you have a reasonable folded-over trim on the handle.
I probably should have explained this first. Sorry.
Old May 18, 2016 | 09:20 AM
  #140
Jonesmeister11
Yeah unfortunately I cut that. Oh well. She enjoys sowing anyway . Are ypu not worried about the wd40 staining or ruining the handle's fake leather or the boot?
Old May 18, 2016 | 09:52 AM
  #141
No, not at all... simply wipe it off and clean up. I just needed something to lubricate the fit, because it was so tight.
Been there, done that.
Old May 18, 2016 | 10:42 AM
  #142
Kris9884's Avatar
Kris9884
So after all this time, have you gotten a CEL/SES light from the test pipes?
Old May 18, 2016 | 11:37 AM
  #143
Jonesmeister11
Nope. I assume this is due to the elbow fast intentions puts on.
Old May 21, 2016 | 11:30 PM
  #144
Jonesmeister11
Just did the lower driver seat mod... Terrible wording...
Anyway, cool mod, but honestly not much of a difference. But at 6'5, any little bit helps right?
Old May 23, 2016 | 11:46 AM
  #145
Kris9884's Avatar
Kris9884
Lets go with the "headroom MOD"
Old May 23, 2016 | 07:48 PM
  #146
Jonesmeister11
Lol better said! It's been a rough couple of days and this week is hard as well. Did this half asleep lol.
Old May 23, 2016 | 08:40 PM
  #147
Jonesmeister11
Just adjusted my clutch pedal. Trying the softest setting for the APF or AFP whatever it's called. Will report back. I don't think I'll be a fan of it, but I think the gf will be able to successfully drive the car.
Old May 26, 2016 | 04:31 PM
  #148
Jonesmeister11
And the flashing tire light is back. After like 2 months. Fantastic.
Old Jun 2, 2016 | 07:02 PM
  #149
Jonesmeister11
The loaner while mine gets diagnosed. Might be a while. Infiniti apparently had a major recall on the Q54, or whatever the big SUV is, timing chain.
Old Jun 7, 2016 | 12:33 PM
  #150
Jonesmeister11
Got the car back. Battery was replaced. Still having the issue *rolls eyes*. I'll drop her back off Friday.
