Deposit made :). Build Thread
Old Feb 19, 2016 | 08:47 AM
  #181
Originally Posted by ANMVQ
Well, so far so good( Please dont be a jinx) I loaded back in my base tune and did a cruise log and Idle log ,Seb has it now. Drove to work( Base tune) this morning tired a few 4th gear pulls, no blinky, I also used my scan tool when I got to work and saw NO codes only 1 INC, EVAP damn this is always INC LOL, But the 02's passed Looks like maybe the cats were no good.
Still going to look at a 07 S4 tomorrow tho. Just incase :/
Don't think Chuckie would be the jinx, but looking at that S4 just might do it
G/L and hope things stay on the uptick
Old Feb 20, 2016 | 10:48 AM
  #182
ANMVQ's Avatar
ANMVQ
well literally at my wits end FN car is still knocking( 7) and pulling 7 deg of timing, No vacum leaks at all , just used aWHOLE can of carb cleaner all over the place and iddle didnt change a bit! Also trying some Lucas "deep" clean injector and fuel system cleaner, other than this I'm out of thoughts, ANYONE?
BTW knocks on my base tune as well :/
Old Feb 20, 2016 | 12:23 PM
  #183
Upscale Speed's Avatar
Upscale Speed
have you changed knock sensors?
Old Feb 20, 2016 | 01:11 PM
  #184
ANMVQ's Avatar
ANMVQ
No trying plugs first , my mafs had water spots on them :/ plugs look :/
Attached Thumbnails Deposit made :). Build Thread-image.jpg
Old Feb 20, 2016 | 01:12 PM
  #185
ANMVQ's Avatar
ANMVQ
Mafs water spots:/
Old Feb 20, 2016 | 01:39 PM
  #186
ANMVQ's Avatar
ANMVQ
I also had a lot of oil in the TBs and in the plenum pics when in done
Old Feb 20, 2016 | 05:09 PM
  #187
ToXIc's Avatar
ToXIc
hopefully these maintenance items does the job and the knock goes away
Old Feb 20, 2016 | 10:08 PM
  #188
ANMVQ's Avatar
ANMVQ
So here's a pick of the TB with oil in it
Old Feb 21, 2016 | 12:23 PM
  #189
ANMVQ's Avatar
ANMVQ
Cars runs a lot better!! Still knocking tho
Old Feb 21, 2016 | 02:55 PM
  #190
Upscale Speed
if you haven't already I'd get some BG44K it's far better than anything in parts stores. At least that's what I've read. I've used it for 10years on all my vehicles and never had a knock issue. Carbon build up on your cylinder walls could be the culprit and looking at those plugs it doesn't look like you were getting a clean burn. Obviously if your knocking your aren't. Changing the plugs and having the car run better is a good sign. Get gas a newer Shell station 93 octane and run the BG44k through for two full tanks and that may solve your problem. Maybe the gas you were getting was ****ty thats why is go to a newer station as their tanks should be cleaner.
Old Feb 21, 2016 | 02:57 PM
  #191
Upscale Speed
I hope you get it back up and running perfect. We need to line them up this spring. If you get an S4 you will smoke me LOL.
Old Feb 22, 2016 | 08:20 AM
  #192
ANMVQ's Avatar
ANMVQ
As far as plugs I used the stock Denso plugs, 3457, I tried some Lucas, Deep clean stuff that one other guy here recommend. I tried 3 different stations since this started, 2 Shells , a Sunoco and even threw in some 100. I'm not sure when I get logs again, Kinda tired of making runs up to 120 and watching for police.
besides a have had a horrible creak/EH-EH noise that's been coming from the front end for 3 weeks not and I need to find out what that is first. I can't drive the car more than 5 MPH with out hearing the noise,
Old Feb 22, 2016 | 02:19 PM
  #193
Upscale Speed
sway bar bushing? sub frame mount maybe?
Old Feb 22, 2016 | 03:11 PM
  #194
ANMVQ's Avatar
ANMVQ
I order the sway bar bushing kit from Kyle shout be here he end of the week, Sub frame, never thought of it, I can push down on the car and recreate the noise also. I'll look at those maybe just need some grease
Old Feb 22, 2016 | 07:28 PM
  #195
Upscale Speed
Actually that very well may be your struts. You have OEM struts lowers on Swifts right? Now may be a good time to pick up a used set of Fortune 500 coilovers or new ones for that matter. If you don't like them or that doesn't fix the issue you could resell them pretty quick is bet and only lose a little. Just a thought.
