My Mod + Dyno Log
Old Nov 24, 2014 | 01:51 PM
  #316
dtea54's Avatar
dtea54
Originally Posted by alfredo24pr
If only they weren't so expensive and rare.
I'll still look into those to see what I can find.
Just go with the eibachs or even coils and spc f+r camber rear endlinks and sways. I know it might stupid since i suggested them but you could leave it at the highest setting. But in your case i would definetly choose the eibach +koni yellows+swaybars and f+r endlinks. I would also look at swift springs to the drop is around 1.0 - 0.8 or 6 in the front and the same with the rears to. Plus you get to choose your own spring rate to your taste which is a plus. You could try koni hsds to.
Old Nov 24, 2014 | 03:38 PM
  #317
GW330's Avatar
GW330
You can also do the least lowering springs up front and cut the rear spring mount to get that 0.3 in drop in the rear. Not the cleanest wat to do it but it works. I have tannabe springs upfront (1 inch drop) in my coupe and stock sport springs in the rear, the car drives great. No camber kit needed. Since it is a relatively inexpensive mod you can easily go back to stock if you dont like the stance or cant get it aligned the way you desire. Buy used springs of your choice and the rubber mounts Part Number: 55050AL500 are cheap also.
Rear spring mount mod
DIY: Cutting Rear Springmount aka "the springmount mod" - Page 3 - G35Driver
Old Nov 24, 2014 | 04:10 PM
  #318
Lego_Maniac's Avatar
Lego_Maniac
You could also flip the front mount on the Konis to raise the front a bit.
Another thing to consider is coupe and/or 370 OE springs.
I think, and this is just my opinion, is that a lot of the 'bottoming out' people complain about is because of the stock dampers. I haven't bottomed out or scraped once since I put on Koni Yellows and Swifts
Old Nov 24, 2014 | 04:48 PM
  #319
alfredo24pr's Avatar
alfredo24pr
Thanks for all the info. I'm leaning towards the Eibach for now, and hoping that I don't scrape and will not require a camber kit.
If the drop causes me to scrape too much, I will look into spring mounts for a slight lift.
Old Nov 24, 2014 | 04:59 PM
  #320
ARK + Drop + PR roads...
Should be fun. GL
Old Nov 24, 2014 | 06:54 PM
  #321
Sway_NV's Avatar
Sway_NV
I'm too young to die!
You really should change the shocks when you change the springs. OEM shocks aren't made to be under the constant stress/compression that lowering springs put on them. I know it's extra $$$ but it will help prevent the things you seem worried about. Just my .02
Old Nov 24, 2014 | 09:41 PM
  #322
alfredo24pr
Should be fun. GL
Thanks. lol
That is also a point that I was concerned about.
You know, I don't really mind the front gap that much that I have to order lowering springs. I just want a slight drop, but it's nothing that I see my car and say: "I NEED to drop it ASAP".
That being said, I will take my time about the final decision.
Old Nov 25, 2014 | 10:09 AM
  #323
Sway_NV's Avatar
Sway_NV
^^^ smart choice.
Old Nov 29, 2014 | 12:37 AM
  #324
alfredo24pr
Washed my car and took a small video showing off the wheels.
Sorry for shakiness. Had to edit with music in it, since there was a lot of background noise.
Old Dec 8, 2014 | 05:29 PM
  #325
alfredo24pr
Finally...after 2 months, the NST pulleys found their way home.
Old Dec 8, 2014 | 06:52 PM
  #326
G37Genova's Avatar
G37Genova
Lets she these gains!!!!!!!1
Old Dec 8, 2014 | 07:14 PM
  #327
Sway_NV's Avatar
Sway_NV
Curious about gains for the pulleys as well...
Old Dec 8, 2014 | 08:07 PM
  #328
alfredo24pr
lol.
I still have to take it to the dyno before getting the pulleys installed, since I changed to lighter wheels.
Also, had a problem with my FI RHFC, so that is setting me back atm :/
Old Dec 8, 2014 | 09:58 PM
  #329
Sway_NV's Avatar
Sway_NV
Oh? What kind of problems with the rhfc? They're on my mod list, anything I need to know?
Old Dec 8, 2014 | 10:17 PM
  #330
alfredo24pr
Get some extra hangers in to support the weight of the RHFC. There is a bracket on the stock cats that you can't reuse in the RHFC install. This thing:
(credit to Rochester for the pic)
