Rochester's new G
Old Jul 11, 2017 | 06:26 AM
  #1846
Lego_Maniac's Avatar
Lego_Maniac
Ideally I'd stick w/ the same fronts when the time comes, and those new improved sidewall inserts on the Contis seem to have addressed any of the previous shortcomings they had.
Also being as detail oriented as you are John, having a mixed set just seems out of place in your case, lol.
+1
Rochester, what's your thought process between mixing the 4S with the Continentals?
Old Jul 11, 2017 | 07:11 AM
  #1847
If the Michelins are more responsive with steering... IDK, really. It was just an idea. Assuming the new Contis have achieved similar performance as the venerable Michelins, it probably doesn't matter. And probably way too much thought about a street tire.
As was pointed out, I'm already content with the Contis on the rear, and they aren't even close yet to being broken in. Even Tire Rack recommends 500 miles for that milestone.
Old Jul 11, 2017 | 01:47 PM
  #1848
2GoRNot2G's Avatar
2GoRNot2G
+100.
I agree with Brad and would stick with the matching fronts if you can. I sold tires for 8 years and always recommended against mixing tires if you don't have to. Putting a completely different tire with a different tread pattern and potentially very different compound can really throw off the handling balance of your car. This is especially true if you try to put two different tires on the same axle, but also applies if your putting on different tires front and rear (i.e. stickier tire on the front could cause the car to become tail happy and vice versa). In addition, sidewall stiffness and ride vary by tires so you could potentially fee the difference as well. Not everyone may notice this difference, but for car guys like us that sometimes drive our cars the way they are meant to be driven I would stick with a complete matching set.
Old Jul 26, 2017 | 06:15 PM
  #1849
Race Ramps - One piece RR-56
Taller, longer, wider, stronger... old, crappy, little car ramps meets the new hotness.
Old Jul 26, 2017 | 06:26 PM
  #1850
ShuuraRG's Avatar
ShuuraRG
I need those!!! I also have the same crappy ones you were using...
Old Jul 26, 2017 | 06:50 PM
  #1851
The old ramps were getting a little bowed, and that was making me nervous. And the 275 rears just didn't fit on the old ramps. Plus, the only way I could get the front end up was to first run the car up on a board.
But now both the front *AND* the rear just runs right up the ramps, no problem.
The ledge is much wider. And a little added height is nice, too. Expensive, sure, but worth it.
Old Jul 26, 2017 | 07:08 PM
  #1852
Cjandura's Avatar
Cjandura
John you should of just got a quickjack like the rest of us aged folk
https://www.quickjack.com
Old Jul 26, 2017 | 09:11 PM
  #1853
ShuuraRG's Avatar
ShuuraRG
I should have purchased one of those when I had the chance last year... It's on my todo list!
Old Jul 27, 2017 | 07:05 AM
  #1854
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
John what would you say the clearance is while pulling the front end up on the ramps? Curious since you dont have the oem lip im sure its a none issue. I still have those old ramps myself and no longer use them unless its for the rear as with my oem lip and splitter now, theres a not a chance I make it up without scrapping or doing further damage.
Old Jul 27, 2017 | 07:20 AM
  #1855
I don't know, except that it wasn't an issue. There's something called the race ramps yardstick test.
Quick Guide to Choosing the Right Race Ramps Car Ramp - OnAllCylinders
Old Jul 27, 2017 | 07:49 AM
  #1856
Daddy Fat Sacs
Thanks, just read it. Will try that out
Old Jul 27, 2017 | 03:17 PM
  #1857
P2M Radiator Hose Clamp
Phase2Motortrend wrote to me a little while ago, to let me know their new 1.65" Hose Clamp was going to be available soon, intended for the radiator hose. Their website wasn't configured for it yet, so they very kindly gave me a paypal account for the $8 it costs, and shipped me one.
Haven't put it on the car yet. Had to take a macro shot on my dining room table first LOL
Old Jul 27, 2017 | 09:08 PM
  #1858
2GoRNot2G's Avatar
2GoRNot2G
Very nice! Me likey! You using those for car shows or what?
Old Jul 27, 2017 | 09:32 PM
  #1859
No, man, I don't have a show car.
I use them to change my oil. And to clean my mufflers. Basic stuff.
Old Jul 28, 2017 | 01:02 PM
  #1860
2GoRNot2G's Avatar
2GoRNot2G
What ever happened to using a jack and jack stands to work on your car? You can even pull the wheels/tires off that way too.
