2-Piece Rotors - Hawk Pads - SS Lines - Stoptech Rotors
Introducing the New CZP 2-Piece Rotors for the 370Z and G37 Sport Models:
We also carry plenty of Hawk pads and Stoptech rotors for both sport and non-sport models. Please PM or call and specify your year and model.
*Custom Powder-Coating now available for Akebono Calipers
_________________________
CZP 2 Piece Rotor Set - Akebono, Slotted - 2pc Front : $749.99
Description: The CZP 2 piece Rotors are 23lbs compared to the 30lbs Stock OEM Rotors. That's a weight savings of 14lbs on both rotors. CZP 2 piece Rotors also include Thermal Stability Profiling (TSP) for improved heat handling, Thermo-Graphic paint markings for effective heat monitoring and Kangaroo Paw ventilation which runs cooler, stronger and outperforms traditional straight vane disc rotors by up to 20%. Our Hats are Aerospace Grade, and use a 6061 Aluminum to allow the disc to expand evenly. This keeps down the heat, and provides additional protection for wheel bearings.
CZP 2 Piece Rotor Set - Akebono, Drilled/Slotted - 2pc Front : $789.99
Stoptech Rotors: Sold as a pair (2-Rotors)
Slotted:
Front Sport Akebono:
Rear Sport Akebono:
Front Non-Sport:
Rear Non-Sport:
Drilled:
Rear Sport Akebono:
Front Non-Sport:
Rear Non-Sport:
Drilled/Slotted:
Rear Sport Akebono:
Front Non-Sport:
Rear Non-Sport:
Hawk Pads:
HPS
Rear Sport Akebono:
Front Non-Sport :
Rear Non-Sport:
__________
Performance Ceramic
Front Sport:
Rear Sport :
__________
HP Plus
Front Sport:
Rear Sport :
Stoptech Performance Street Pads:
Front Non-Sport Akebono:
Rear Sport Akebono:
Rear Non-Sport Akebono:
CZP 370Z Teflon Coated Stainless Steel Brake Lines
Stoptech SS Brake Lines Front & Rear (available as Front or Rear Set also)
Motul 100949 RBF 600 Racing Brake Fluid DOT 4, 3-Pack
Motul 100951 Dot 5.1 Synthetic Racing Brake / Clutch Fluid, 3-Pack
Powder Coating for Akebono Calipers:
COZ
Slotted:
Rear Sport Akebono:
Front Non-Sport:
Rear Non-Sport:
Drilled:
Rear Sport Akebono:
Front Non-Sport:
Rear Non-Sport:
Drilled/Slotted:
Rear Sport Akebono:
Front Non-Sport:
Rear Non-Sport:
Hawk Pads:
HPS
Rear Sport Akebono:
Front Non-Sport :
Rear Non-Sport:
__________
Performance Ceramic
Front Sport:
Rear Sport :
__________
HP Plus
Front Sport:
Rear Sport :
Rear Sport Akebono:
COZ
Subscribed
