Special Motive Power Bleeder from Jeb Performance
Old 03-11-2011, 03:50 PM
JEBperformance
JEBperformance's Avatar
Braking system when fluids exceed boiling point will produce bubble inside your calipers. Reducing braking power, fading may occur, and reduce longevity of your brake system.
Bleeding you brake can be little tricky. Primitive way of bleeding would be one person pumping the brakes while another person would open and close the bleeder nipples. Primitive but effective. But takes two person.
I have used in the past many bleeding system. Most common you will see on the market are vacuum system attached to nipples while you open and close the valve. This way of bleeding is tedious and ineffective.
Motive a racing products manufacturer have come up with brilliant idea. Apply pressure to your master cylinder. Using their kit is most convenient, effective, and yes takes only one person. Done in no time.
Jeb Performance recommend your brake system to be bled at least once every time you change your brake pads or rotors.
Retail Price on Motive Power Bleeder Kit 0107 is $64.95 plus shipping. You will not find elsewhere. Kit comes with following parts. Bleeder, Adapter which fits Infiniti/Nissan, Subaru, and Dodge. So there is nothing else to buy. Also we provide adapters only, for your application on any vehicle please refer to Motive Adapter and Bleeder Application GUIDE.
Instructions on how to use, and to see how easy they are. Please watch instructional video provided by Motive Products. The video is not narrated so there is nothing wrong with your sound system.
Order your Motive Power Bleeder @ POWER BLEEDER - JEB Performance, Inc. - Thousands of after market tuning parts for less
<iframe title="YouTube video player" src="http://www.youtube.com/embed/d0h5bMoW-aw?rel=0" allowfullscreen="" frameborder="0" height="510" width="853"></iframe>
Old 03-16-2011, 01:45 PM
JEBperformance
Used them myself over the weekend at the Buttonwillow Race Track. They are great. We were able to bleed all 4 brake system. Less than 10 minutes.
Old 03-17-2011, 02:26 PM
JEBperformance
Make sure to use SAE Wrench to tightly fasten the bolt. Your hand will not be strong enough to ensure air tight seal.
Old 03-21-2011, 01:24 PM
JEBperformance
Monday Bump
Old 03-25-2011, 01:56 PM
JEBperformance
weekend bump
Old 03-25-2011, 11:01 PM
JEBperformance
Bump bump bump
Old 03-31-2011, 12:23 AM
JEBperformance
Motive Power Bleeder ables one person to do what normally requires two
Old 03-31-2011, 09:10 PM
JEBperformance
Best value and easy application. Only with MOTIVE power bleeder.
Old 04-04-2011, 01:27 PM
JEBperformance
Old 04-08-2011, 12:16 PM
JEBperformance
I have used number of bleeders in the past. All got trashed, simply did not work or was not up to my expectations.
Motive Power Bleeder exceeds all my expectations, and more. Order yours now.
Old 04-11-2011, 02:30 PM
JEBperformance
Mr Matt Thank you for your payment
Old 04-15-2011, 12:35 AM
JEBperformance
Make sure to empty your bottle after each and every use. Once seal if broken and exposed to air and humidity, brake fluid tend to absorb excess moisture. Resulting in forming bubbles inside your brake line.
Old 04-19-2011, 08:11 PM
JEBperformance
Only bleeder designed for Infiniti/Nissan
Old 04-21-2011, 03:07 PM
JEBperformance
For those DIY guys Motive Power Bleeder is a must for your garage.
Old 04-28-2011, 08:46 PM
JEBperformance
Motive best bleeder ever
Quick Reply: Special Motive Power Bleeder from Jeb Performance
