Front end violently shakes at certain speeds
Old Jan 5, 2021 | 10:35 PM
Isxlow's Avatar
Isxlow
Hi all, I recently noticed my G37 is starting to violently shake when accelerating up between 80-85mph. It starts out as a vibration then turns into a up and down shaking motion. The shaking feels like its coming from the front end of the car and when I accelerate past that range the car will stop shaking and drive normally again. Any time I drive below that speed the car also performs perfectly. Anyone have any idea what this could be? Mounted new tires today but is still happening so I don't think its a tire balancing issue. Any help is appreciated!
Old Jan 5, 2021 | 11:24 PM
04G35NYC's Avatar
04G35NYC
Balance your wheels, also check if you have any bubbles
Old Jan 6, 2021 | 09:10 AM
sobeIPL's Avatar
sobeIPL
Could be a bent wheel. One of my IPL was bent and caused bad shaking at same speeds.
Old Jan 8, 2021 | 09:59 PM
Hugh Jorgens's Avatar
Hugh Jorgens
Is your car AWD or is it RWD?
Have you had it inspected for loose bolts or bad/worn parts?
Old Jan 9, 2021 | 12:08 AM
Joyryde's Avatar
Joyryde
Could be the control arms too. Or transaxle. Happened to a small batch of Gs depending on the year: https://infinitig37.com/TSB/ITB11-019.pdf
jscho5
Dec 10, 2023 11:41 AM
Modme
21
May 18, 2020 08:14 PM
Jsbach1685
Oct 1, 2019 08:27 AM
Primo55
Feb 8, 2014 08:31 AM
LexiG37
Nov 7, 2012 03:52 PM
