Shocks or Struts? HELP
Old Jan 25, 2020 | 01:35 PM
slartibartfast's Avatar
slartibartfast
You car does not have struts. It has a coil-over damper up front and separate spring/damper in the rear. It is so sad that people can't get this through their heads and parts houses had to adopt "strut" for any style front suspension.
Old Jan 25, 2020 | 01:37 PM
OldG2NewG's Avatar
OldG2NewG
Rockauto has them listed under struts and here ya go OP
Old Jan 25, 2020 | 01:45 PM
G37xMN's Avatar
G37xMN
THIS is what I was looking for when I asked if we have shocks or struts. I tried googling it multiple times and nothing came up. Thank you for clearing it up.
Old Jan 25, 2020 | 01:46 PM
G37xMN's Avatar
G37xMN
Thank you. I had found those but thought there was shocks I needed to purchase as well.
Old Feb 3, 2020 | 08:42 AM
Surfnazi's Avatar
Surfnazi
Make sure endlinks bolts arent loose or endlink isnt torn bc once it tears and grease is gone it will clunk when you drive over bumps at low speeds
Old Feb 4, 2020 | 03:35 PM
G37xMN's Avatar
G37xMN
So here’s how 3/4 endlinks look out of the package. They were really bent inward and when I bent them back to straight the boot didn’t really come with it. There’s a gap.
Edit: should i make a return or is this normal? Doesn’t look to me like it’s torn but in my mind it looks like grease will escape.
Old Feb 5, 2020 | 01:56 PM
slartibartfast
Why did you post this in both of your threads here in the suspension forum? Once is enough.
Old Feb 5, 2020 | 02:00 PM
G37xMN's Avatar
G37xMN
I posted it here, then realized someone on my other thread had replied with their experience with the same part. My apologies.
Old May 16, 2021 | 08:26 PM
Rich11G37xS's Avatar
Rich11G37xS
Sound like this??
Just had my fronts done , I’m thinking I might need bushings or a new strut tower
Originally Posted by G37xMN
So ever since I’ve bought my car, I’ve noticed there’s a clunking noise. I’ll start off by saying it’s a 2012 G37X Sedan. I’ve replaced both Lower Control Arms, Inner and Outer Tie Rods, CV axles, and wheel hub assemblies. (All front end) and the clunking still resides! My next guess is the shocks/struts, but I can only find Strut assembly’s online. Do we not have shocks? I’m looking at getting the pre-assembled strut tower from 1aAuto. Comes with spring, strut mount, and the strut itself. Also, when I go over bumps my steering wheel shakes left and right. (Like it’s turning) so that’s why I think my struts/shocks are bad.
chris_s
Sep 8, 2015 03:37 PM
TVPostSound
Jul 12, 2011 01:03 AM
VIP G
Brakes
Apr 2, 2009 12:07 PM
C@ciQ
Nov 12, 2008 12:22 AM
