G37 steering wheel making noise burning smell when turning
Old Jan 4, 2020 | 01:15 PM
G37ampandmusic's Avatar
G37ampandmusic
So something is wrong with my g37x steering wheel. When I drive slow around turns it makes an awful sound of like friction it's very hard for me to park my car in a lot and back out as my steering barely turns but seems to work like nothing is wrong when I go fast. My fluids have checked out fine.. dunno what's causing it. Anybody have suggestions? Brought it to my mechanic he thinks it's a leaking hose but that still wouldn't explain my situation.. at least I would think.
Also seems to smell up my car of rubber or something when I turn...
Old Jan 4, 2020 | 11:34 PM
PNW_IPL's Avatar
PNW_IPL
Your power steering pump sounds like fluid ran dry and the pump is burning out. Check power steering fluid.
Old Jan 5, 2020 | 05:36 PM
Conboss's Avatar
Conboss
If you have fluid and the reservoir is supplying, but its still acting up at low speeds, I would say your pump might be on its way out. Sadly mine is on the way out as well, just starting to make some funky noises. DIY here I come!
Old Jan 9, 2020 | 04:08 PM
Rooster Tail's Avatar
Rooster Tail
Fluid is fine? Then perhaps the smell is coming from the belt burning? It could be loose/old, or the power steering pump is seizing and causing the belt to slip.
Does it happen when turning the wheel at full lock or even at less than that?
BeeW
26
Mar 9, 2021 02:01 PM
myjee37
General Tech Questions
Sep 7, 2019 01:26 AM
ryanwhite74115
Nov 22, 2016 03:55 PM
MoonlightG/S
Jan 22, 2015 08:06 PM
kkokko
May 31, 2009 01:56 PM
