Help Advice on tire size
Old Aug 5, 2012 | 07:52 PM
ashecnc's Avatar
ashecnc
Advice on tire size
I decided I wanted the same size wheels/tires , I am not a fan of staggered setup, just my opinion. I have 4 wheels that are 5 114.3 19x9 all 4 offset 30 all around. I like a good size tire, how would 255/35/19 fit all around, ok in the front that wide on 19x9 wheels, thank you!!
***I have decided 245-40-19
Old Aug 7, 2012 | 02:08 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Nice! 245/40-19 is the better choice there.
Old Apr 12, 2020 | 09:20 PM
slawek65's Avatar
slawek65
Originally Posted by adammickel
you can run up to 20x11.5 fine. 5x112 is your cars bolt pattern, make sure re hub is correct fit tho. Your car has wheel bolts not studs, may need extendo bolts depending on rim width you can figure out your tires from super slim to really fat you can fit a plethora of sizes based on look and function
what ???
Old Apr 13, 2020 | 08:07 AM
projectpanda13's Avatar
projectpanda13
You can run up to 20x11.5 fine. 5x112 is your cars bolt pattern, make sure re hub is correct fit tho. Your car has wheel bolts not studs, may need extendo bolts Depending on rim width you can figure out your tires from super slim to really fat you can fit a plethora of sizes based on look and function
not 5x112, that's most european cars. our cars run a 5x114.3
Wheel bolts are also used on some European cars like BMW. Our cars use studs.
Old Apr 13, 2020 | 09:49 AM
8 year old thread needlessly bumped with a word salad of misinformation. We're done here.
/closed
LinGL
Oct 30, 2018 08:44 AM
TaylorMade93
Sep 17, 2013 04:40 PM
Samer Serhan
Jul 9, 2013 08:24 PM
Link20
Jul 15, 2012 12:21 PM
qusfbf92
Mar 6, 2011 12:07 AM
