Vibration and clicking noises
Old Sep 18, 2019 | 01:54 PM
Snaoum's Avatar
Snaoum
Recently I redid my brakes, installed new Raybestos rotors, new pads. Car stops really well.
I am noticing as of this week that when coming to a stop, just before a complete stop I hear almost like a clicking noises until the car stops. I am almost certain it is from the left front wheel. I have double checked the tightness of the wheel and calipers, pads, hardware look fine. To top it off, I am also experiencing steering vibration starting around 70mph. I had the wheels balanced but still feel a vibration.
Any suggestions to what I should look for would be great. Thanks.
Old Sep 19, 2019 | 10:58 AM
Baadnewsburr's Avatar
Baadnewsburr
for the noise, do you have the base or akebono brakes? some have reported loose caliper components in the base brakes causing noise.
Also check to see if the dust shield got bent or there is any debris anywhere between the dust shield and rotor and is hitting the rotor...you might see a grove on the back of the rotor being worn in.
Old Sep 19, 2019 | 02:11 PM
Snaoum's Avatar
Snaoum
I have a xS sedan, so base brakes
Old Sep 19, 2019 | 06:08 PM
GoatBeard's Avatar
GoatBeard
Did you experience the vibration and clicking immediately after installing the new parts? Or was everything fine for a short time afterwards, and then appeared?
Old Sep 20, 2019 | 07:09 AM
Snaoum's Avatar
Snaoum
I want to say this started after the new parts, but I rarely driveway highway so I am not sure when the vibration started. I am positive the clicking noise when pressing the brake was not there before new rotors. I think I need to double check that hardware is tight and moving parts are greased and go from there.
Old Sep 21, 2019 | 08:22 PM
Surfnazi's Avatar
Surfnazi
Clicking could be brake pads add some copper grease to back of pads
Old Oct 3, 2019 | 08:36 AM
Snaoum's Avatar
Snaoum
Fixed. Re-greased the pads in the front.
nogoer
Aug 30, 2017 01:16 PM
Marionan
Mar 3, 2017 06:18 PM
iGGy37S
Jul 13, 2015 02:23 PM
ben_ben125
Oct 5, 2011 06:22 PM
slyfercombat
Apr 21, 2010 10:44 AM
