Recommendations
Old Jun 7, 2018 | 02:26 PM
VQ37VHR13's Avatar
VQ37VHR13
Recommendations
Hey all,
Just pulled the trigger on some coilovers. Now according to the picture attached, is that all i would need to be good for alignment? Would you add anything else? I don't want to keep the stock bucket.
Old Jun 7, 2018 | 02:44 PM
VQ37VHR13's Avatar
VQ37VHR13
Originally Posted by VQ37VHR13
Hey all,
I'll add that i currently have Hotchkis sway bars, moog endlinks. I'm also not trying to be crazy low
Old Jun 7, 2018 | 03:29 PM
slartibartfast's Avatar
slartibartfast
I think you covered the bases.
Old Jun 7, 2018 | 04:27 PM
If you don't want to keep the stock spring bucket you'll need toe arms rather than the toe bolts to adjust toe settings.
Old Jun 7, 2018 | 08:14 PM
slartibartfast
Only true-type coil-overs can dispense with rear spring bucket/control arm.
Also, AWD severely limits the number of coil-over options you have, something like five.
Old Jun 7, 2018 | 11:20 PM
VQ37VHR13's Avatar
VQ37VHR13
Is it better to keep the bucket in your opinion?
I bought Feal 441 with Swifts or Feal 441+ as they refer to it now.. Should be fine right?
Old Jun 8, 2018 | 08:50 AM
It's really up to you regarding elimination of the Spring bucket (aka lower control arm), it would reduce a bit of weight and make for a cleaner look. Not sure if there's much of an advantage except for the greater adjustment range of the toe arms, and you wouldn't be cutting into your car to elongate the oem slots.
If you haven't seen this thread you might contact the OP and see if he has any other suggestions, I think he's still running the buckets though.
https://www.myg37.com/forums/brakes-...37x-sedan.html
Old Jun 8, 2018 | 02:37 PM
slartibartfast
The guys on the 370Z boards argue that the upper damper mount in the body isn't designed to take the loads imposed by the springs which could cause distortion or failure. Others say that as long as you aren't a track rat that the body can deal with the loads. Don't think there has been a case of failure yet, but who really knows?
